Projects S.E.G.A. Olds build
Discussion in 'Traditional Hot Rods' started by Saturn V, Oct 11, 2021.
  1. spanners
    spanners
    I like this sort of engineering. I can't do it for ****, but I like watching others.
    ClutchDumpinDan, OahuEli and Saturn V like this.
  2. Saturn V
    Saturn V
    from Killen AL
    While I was setting up the next block, I took a couple of pics of the line up bolts I machined to help locate and stabilize the block on the mill table. IMG_20220328_185907135.jpg IMG_20220328_190810974.jpg
    OahuEli, brEad, ottoman and 3 others like this.
  3. bobss396
    bobss396
    The t-slots are the best way to keep something square. I'm a bug about keeping mine clean and not gouged up.
    Saturn V likes this.
  4. Saturn V
    Saturn V
    from Killen AL
    A little die-grinder work and this step will be done. IMG_20220402_133820338.jpg IMG_20220402_133747090_HDR.jpg
  5. Learn new stuff here everyday. Thanks.
    OahuEli, Saturn V and SS327 like this.
  6. seb fontana
    seb fontana
    from ct
    Is block flat on table? Guide bolt end looks like sitting on bearing web/rail surface while other end looks like hanging off table resting on bearing cap surface.
    chryslerfan55 and Saturn V like this.
  7. Saturn V
    Saturn V
    from Killen AL
    I have a pair of parraelles under the main cap parting line. I do a skim cut on the china walls. When I flip it to do the 4- bolt conversion it helps keep the main saddles even with the table.
  8. Saturn V
    Saturn V
    from Killen AL
    Up date from the ch***is shop. IMG_20220402_150846.jpg IMG_20220402_150853.jpg IMG_20220402_150858.jpg IMG_20220402_150903.jpg IMG_20220402_150910.jpg IMG_20220402_150915.jpg IMG_20220402_150921.jpg
    OahuEli, winr, brEad and 4 others like this.
  9. seb fontana
    seb fontana
    from ct
    Ah roll bar time. I guy I know has a PU Truck with a big blown BBC engine. He had a roll bar put in and the back down tubes are bolted together where they go through the roof above the rear window, flange on each side of sheet metal. Fabricator claimed its good for 8.5 cert [not that he is ever going to run it] but I am curious if it really is?
  10. 4ever18
    4ever18
    Pontiac/Olds 9.3” or is that a 9” Ford rear?
  11. Saturn V
    Saturn V
    from Killen AL
    9", the 9.3 Olds is impossible to find in my area, plus the parts selection for the Ford is great!
    bobss396 and 4ever18 like this.
  12. 4ever18
    4ever18
    Thank you. The 9.3” parts are MUCH more expensive, most certainly. I’m using a 9.3” in my early 60’s inspired’34 Ford coupe project. I bought my parts from FabCraft. They are great to deal with, but these low volume parts are expensive. If I remember correctly, a pair of axles/bearings/seals/studs/retaining plated were around $700. But, that’s what I wanted. Yes, it’s way overkill for a SBC 283(bored to 301) & Borg Warner T10 4 speed.
    Saturn V and Tickety Boo like this.
  13. bchctybob
    bchctybob
    I understand the cut in the timing gear area but why the cut in the valley? I’m not at all familiar with the later Olds engines, just curious.
    Nice work your ch***is guy is doing with the roll bar.
    Saturn V, seb fontana and 427 sleeper like this.
  14. Saturn V
    Saturn V
    from Killen AL
    When running a roller cam, the injector boss in the lifter valley interferes with the link bar on number 1 cyl. If a flat tappet cam is used, there would be no need to machine it out.
    bchctybob, Outback, ottoman and 2 others like this.
  15. Saturn V
    Saturn V
    from Killen AL
    OahuEli, bobss396 and 427 sleeper like this.
  16. Saturn V
    Saturn V
    from Killen AL
    Another update on the cage progress! IMG_20220405_095547.jpg IMG_20220405_095554.jpg IMG_20220405_095600.jpg IMG_20220405_095607.jpg IMG_20220405_095625.jpg IMG_20220405_095637.jpg
    brEad, Just Gary, Tman and 3 others like this.
  17. Saturn V
    Saturn V
    from Killen AL
    Cage is finished,,,time for a road trip!! IMG_20220406_170557.jpg IMG_20220406_170608.jpg IMG_20220406_170614.jpg IMG_20220406_170618.jpg IMG_20220406_170624.jpg IMG_20220406_170631.jpg IMG_20220406_170636.jpg
    winr, bchctybob, Just Gary and 7 others like this.
  18. “Update from the ch***is shop” is kinda like saying “took my car to a pretty good garage in Daytona”! Wish I woulda taken him up on his offer to see his shop last year. And I really wish I was able to have my cage done by him.
    bchctybob likes this.
  19. Saturn V
    Saturn V
    from Killen AL
    I was glad they took in my job,, it's hard for me to crawl around inside a car now. Very pleased with the job! Wished I was still able to do it all myself, but age gets us all. Some sooner than others.
    OahuEli, bchctybob, wvenfield and 7 others like this.
  20. Garlic Slinger
    Garlic Slinger
    I appreciate you explaining all of the work to convert the block to gasoline. I am considering converting my 350 D block so it's great to see what it really takes.
    Just Gary and Saturn V like this.
  21. Saturn V
    Saturn V
    from Killen AL
    You are welcome,,, waiting on the main caps now. When I get them, I'll post about the main web machining and drilling.
    A lot of what I'm doing for this engine could be deleted for a simple street build.
    SilverJimmy likes this.
  22. Saturn V
    Saturn V
    from Killen AL
    Friends stopped by with one of their CNC front caps for the diesel Olds. Nice piece! We test fit it on a block. Just a couple of small changes need to be made. Then I will be seeing a full set at my front door! IMG_20220416_113507632.jpg IMG_20220416_113511375.jpg
  23. 427 sleeper
    427 sleeper
    That a killer piece of work! :cool: Along with everything you're doing, too!!! :cool::cool::cool:
  24. Saturn V
    Saturn V
    from Killen AL
    I am fortunate,, I have a lot of friends with talents that want to be a part of this project! I am more than happy to let them show off what they can do!!
  25. Those main caps are way to pretty to hide under an oil pan.
    OahuEli, 427 sleeper and Saturn V like this.
  26. 6sally6
    6sally6
    Looks like everything you've built should stand up to FULL throttle...side stepp'in power shifts....7 grand RPM launches..no problem!!
    Talk about super duty (Oldsmobile-style)
    Put that puppy on a serious diet and you'll be a contender fer sure!!
    Whew!!!!!
    6sally6
  27. Saturn V
    Saturn V
    from Killen AL
    When no one in town has degree shims to set caster on a straight axle,,,just make them!! IMG_20220418_183047535.jpg IMG_20220418_185614406.jpg IMG_20220418_184411089.jpg
  28. Saturn V
    Saturn V
    from Killen AL
    Not totally satisfied with the drag link angles, but I think for straight line I think it will work....still need to get weight on the springs to get the axle in line with the axle...wished I would have studied up on this more before mounting the box!!! Live and learn! This is my 1st straight axle car! IMG_20220423_144252089.jpg
    bchctybob and slayer like this.
  29. Saturn V
    Saturn V
    from Killen AL
    This had been a fun learning experience for sure!!!
    OahuEli likes this.
  30. Saturn V
    Saturn V
    from Killen AL
    Got this pic just a few minutes ago! I'll have main caps soon!!! IMG_20220423_193214.jpg
    winr, OahuEli, brEad and 10 others like this.
