*** S O L D *** 59 A. BIG BORE-SHORT STROKE, rebuilt short block flathead
Discussion in 'Parts For Sale' started by Frames, Dec 20, 2020.
  1. Frames
    Frames
    City: CONCORD
    State: North Carolina
    Price: $4,400.00
    3 3/8" bore x 3 3/4" stroke. 258 C. I. D . Getting closer to how all late model engines are built. Egge pistons have been CALICO [ black ] coated for scuff resistance! Mild port and relieved. HUGH PORT job [ sorely needed on a flathead ] on the exhaust. 1.6" power flow stainless valves. Feather light Johnson lifters. Zephyr valve springs. Isky # 88 camshaft. 264 duration. 320 " lift. Short block assembled with an oil pump and o 2020-12-20 11.22.35-2.jpg 2020-12-20 11.22.35-1.jpg 2020-12-20 11.22.35-3.jpg 2020-12-20 11.22.35-4.jpg 2020-12-20 11.22.35-5.jpg 2020-12-20 11.22.35-6.jpg 2020-12-20 11.22.35-7.jpg 2020-12-20 11.22.35-9.jpg 2020-12-20 11.22.35-12.jpg 2020-12-20 11.22.35-13.jpg 2020-12-20 11.22.35-14.jpg il pan. $4,400.00. Installing crank and pistons 12-21-20. I have all the parts to complete this engine if you need them. OPTIONAL at extra cost. Dennis 704 788 8225
    alanp561 likes this.
  2. Frames
    Frames
    1-4-21 Short block is done. NOTE the center main bearing support. A racing engine trick from the early days when flatheads were king. I like to use 8BA crankshafts and 8BA rods with insert type bearings. 2020-12-24 11.05.11.jpg
  3. Frames
    Frames
    2020-12-29 14.24.21-1.jpg 2020-12-29 14.24.21-2.jpg 2020-12-29 14.24.21-3.jpg 2020-12-29 14.24.21-4.jpg bttt. Rebuilt starter. Flywheel resurfaced. New pilot bearing. NOS 10" pressure plate. Use a disc that fits your trans. spline. Right side water pump back ordered.
    Petejoe and Andy Lowery like this.
  4. Frames
    Frames
  5. Frames
    Frames
  6. Frames
    Frames
  7. Frames
    Frames
  8. Frames
    Frames
  9. Frames
    Frames
  10. Frames
    Frames
