View attachment 5027020 View attachment 5027021 Good 59A blocks are very hard to find. 59L blocks are even harder to find. They are supposed to have more nickle content. This block had one crack in a non critical area. See magic marker. It was repaired with IronTite plugs. It is a permanent repair. Many engine builders even use it in the combustion chambers. Offenhauser pistons and rings. Fresh Holman & Moody L100 camshaft. This grind is half way between an Isky Max 88 and a 400JR. Isky lifters. Zephyr valve springs, Ford exhaust valves. 1.6" power flow intake valves. The 8BA crankshaft is standard. Only required polishing. It came from Dennis Carpenter Reproductions. 8BA rods also. $3,700.00 short block only with timing gears installed. $300.00 shipping and crating. I have many optional parts if you need them. See pictures. Inquire. 704 788 8225 NO TEXT
