S10 clip in a Ford shoebox
Discussion in 'The Hokey Ass Message Board' started by drunknbroke, Mar 8, 2010.
  1. drunknbroke
    drunknbroke
    What are the pros and cons of putting one in? Thanx
  2. Obsessedwithchop
    Obsessedwithchop
    cons are you are going to have to rework the frame rails so they match up and then you will have to do a little work getting the steering column and the steering box turning like it should without binding....not to big a deal if you got a little skill.
    pros updated suspension with disc and there are a ton of parts for theses suspensions tubular amrs drop spindles and airbagin aint a problem:cool:
    I'm sure I might be missin a few things but I'm at work;)
  3. shoebox50
    shoebox50
    I did a s10 clip on my 50 . Its alot of work but its worth it when you drive it.
  4. Ryan
    Ryan
    ADMINISTRATOR
    There is absolutely nothing wrong with the sock front-end. Spend the effort and money elsewhere.
