I heard it is easy to install S10 front disc brakes on early falcons. Does anyone have tech info on this conversion.
make sure you get the right set-up. Some of those brackets mix and match different make/motel calipers and rotors. Granada spindles are still around but are getting harder to find, but at least you can keep the ford bolt pattern. Unless that isn't a problem
