S10 rear end codes. "GAK???"
Discussion in 'The Hokey Ass Message Board' started by seymour, Nov 9, 2004.
  1. seymour
    seymour
    from PNW
    anyone know what gear are in those? I've never seen that code before.
    TIA
  2. flatheadpete
    flatheadpete
    from Burton, MI
    I'll try to find out tomorrow at work. Any idea what year it is?
  3. seymour
    seymour
    from PNW
    thank you very much. it'd be greatly appreciated. i'm unsure of the year, but i'll email him and ask him.
  4. willowbilly3
    willowbilly3
    from Sturgis
    Maybe GAK is the code for the bottom end on the 2.8. [​IMG] It sounds fitting anyway.
  5. BPD
    BPD
  6. Jack Daniel
    Jack Daniel
    from Lavon, Tx
    GM part number is 15551410. It's an open 7.5 rear with 3.73 gears. It only fits s series trucks from 85-91. Hope that helps. [​IMG]
  7. seymour
    seymour
    from PNW
    jimmybeamer - thank you very much for looking it up for me. quick Q, isn't 3.73 supposed to say GT4? I'm sure the marking could've wore off by now.
  8. flatheadpete
    flatheadpete
    from Burton, MI
    I believe GT4 is 3:73 speak for 8 1/2 rear ends.
  9. Model A Vette
    Model A Vette
    GT4 was the ratio code on the 3.73 rear I pulled out of a '93 S10 with a friend recently. It was the 7.50.
  10. VSO737
    VSO737
    Hi,
    I need to ID the axle code: GAK K095 3
    I need to know the gear ratio.
    The rear axle came off of a 1991 Chevy S10 two wheel drive truck.
    For some reason the VIN# was looked up at the Chevy dealer with NEGATIVE results.
    Thanks,
    Mike
    :cool:
  11. Hackerbilt
    Hackerbilt
    Keep the truck from rolling and jack up one rear wheel.
    If the rearend is out...just prevent one wheel from turning. (NO turning at all or your count will be off)
    Mark a line on the driveshaft flange and the rearend housing so you can count turns.
    Rotate the tire TWO turns exactly and count the number of revolutions of the driveshaft.
    Just over 3 will be 3.08's (or whatever GM used in those rearends)
    Almost 3 and a 1/2 will be 3.43's.
    3 and 3/4 will be 3.73's.
    Just over 4 turns will be 4.11's.
    This will work even if its a GM Gov-Loc Posi because they remain unlocked until a certain amount of slippage with one wheel is detected.
    With a regular Posi you jack up BOTH wheels and spin the tires once. No diff action due to the stiff clutches in the Posi so the double rotation isn't required.
    Have you looked in the glove box for the option sticker and found the rear axle code?
    I've never seen one listed out like that. Usually just a 3 number/letter combo.
  12. VSO737
    VSO737
    FOUND IT............
    GAK ............corresponds to a 3.73 gear ratio
    Thanks again,
    Mike
