Hot Rods S10 rear end
Discussion in 'The Hokey Ass Message Board' started by BC Texas, Apr 20, 2017.
  1. BC Texas
    BC Texas
    from Arp. Texas
    I have been running a 36 rear end, spring and and radius rods on my model a. Rear end gone bad. Would like to use an s-10 rear that I have. I have attached radius rod brackets to the s-10 and had to narrow them. I have 40-1/2" spring hanger to spring hanger, which makes my spring too long. My spring is a 37 ( I think).
    What song will work well for me?
  2. the-rodster
    the-rodster
    "Too Wild, Too Long" - George Jones
  3. Go to a spring shop and get a new main leaf the proper length made up then restack your spring. You may have to shorten your leaves but it will give you a chance to chamfer them any way. You use a cut off wheel or a stone on your angle grinder to shorten them.
    gimpyshotrods likes this.
  4. gimpyshotrods
    gimpyshotrods
    ^^What he said.^^
  5. thirtytwo
    thirtytwo
    If you really have a 35-40 spring they like the eyelets on the rear around 48" so you can have a new main leaf made narrower the corrisponding amount
  6. flatheadpete
    flatheadpete
    from Burton, MI
    Song?
    'Take This Job and Shove It' -Johnny Paycheck.
  7. This one?
    flatheadpete likes this.
  8. Jalopy Joker
    Jalopy Joker
    what gear ratio in S10?
  9. scrap metal 48
    scrap metal 48
    There are many ratios.. A lot of them are 3.42...
  10. The banger 2WD 5 speed was a 4.10 in most of them. They are a little narrower than most people like though.
  11. gimpyshotrods
    gimpyshotrods
    Most of us idiots use a 4x4 one. Those are 58" wide.
    Those are:
    3.42 axle ratio (opt GU6)
    3.73 ratio (opt GT4)
    4.11 ratio (opt H04)
    3.08 ratio (opt GU4)
    As far as I know, the 2wd ones had the same ratio spread, too.
