S10 T4 Transmission
Discussion in 'Parts For Sale' started by ididntdoit1960, Oct 2, 2025.
  1. ididntdoit1960
    ididntdoit1960
    from Western MA
    City: Agawam
    State: Massachusetts
    Price: 650
    This is out of an '82 s10 - dimensionally same as a T5 but no 5th gear - lighter weight and a bit more compact - mount is a little further forward with no bulge on either side of the tail where 5th normally is- it has a mechanical speedometer hook up - 4.03 first gear with 1:1 4th - same input shaft and bolt pattern as an '82-'93 s10 T5 so can use all available T5 adapters or bolt direct to chevy bell. Works great with a 3.08 or higher (lower numerically) gear or tall tires - depending on rear gear ratio, a car set up with an s10 T5 often has either a too low overall takeoff ratio and 1st gear is way too short, or it cant pull OD at less than 80MPH.....Its the trans on the right in the pic and it includes the shifter - turns over freely and shifts through the gears - for comparison the trans in the middle is an '87 Camaro v8 T5 with a '93 s10 tail and the one to the left is a saginaw 4 speed
    51 mercules likes this.
  2. ididntdoit1960
    ididntdoit1960
    from Western MA
  3. ididntdoit1960
    ididntdoit1960
    from Western MA
  4. ididntdoit1960
    ididntdoit1960
    from Western MA
  5. ididntdoit1960
    ididntdoit1960
    from Western MA
  6. ididntdoit1960
    ididntdoit1960
    from Western MA
    Make an offer - trades good too
  7. ididntdoit1960
    ididntdoit1960
    from Western MA
  8. ididntdoit1960
    ididntdoit1960
    from Western MA
    BTT - make offer - will be driving down the east coast on I95 next week
  9. ididntdoit1960
    ididntdoit1960
    from Western MA
  10. ididntdoit1960
    ididntdoit1960
    from Western MA
  11. ididntdoit1960
    ididntdoit1960
    from Western MA
  12. ididntdoit1960
    ididntdoit1960
    from Western MA
    BTT
  13. ididntdoit1960
    ididntdoit1960
    from Western MA
  14. ididntdoit1960
    ididntdoit1960
    from Western MA
  15. ididntdoit1960
    ididntdoit1960
    from Western MA
  16. ididntdoit1960
    ididntdoit1960
    from Western MA
  17. ididntdoit1960
    ididntdoit1960
    from Western MA
