Technical Safety Hub question
Discussion in 'Traditional Hot Rods' started by trucker1, Feb 6, 2016.
  1. trucker1
    trucker1
    I have adapted 1946 brakes to a Model A rear axle and I've welded the steel rings on the inside of the hub with the aluminum block in place on each one. I had a machine shop rotate and re-drill the backing plates to clear the spring perch. There must be a bolt circle difference of about 1/16" between the v8 holes and the Model A holes. Would someone advise whether to bore the axle holes larger or slot the holes in the housing. Thanks, Glynn.
  2. Jalopy Joker
    Jalopy Joker
  3. Pete1
    Pete1
    from Wa.
    Either way will work.
  4. trucker1
    trucker1
    Thanks for the reply , I think I'll try out my adjustable reamers on it.
