History Safety Signal Spark Plug whistle... WTF??
Discussion in 'The Hokey Ass Message Board' started by 49ratfink, Oct 6, 2009.
  1. 49ratfink
    49ratfink
    anybody ever seen one of these things?? were they used on cars? seems to me that would hinder performance. at the very least you would drive down the street tooting as you go.
    I don't have it... just something I saw perusing the interweb.
      85.3 KB
      931 bytes
      118.6 KB
  2. squirrel
    might be useful for timing the engine if you're trying to find tdc on the compression stroke.
  3. Model T restorer toy. My dad had one on his A Vicky at one time. Yeah their F ing loud!
  4. 49ratfink
    49ratfink
    so how did it run with one cylinder leaking?
  5. temper_mental
    temper_mental
    from Texas
    Wow that would be very loud
    plym_46 likes this.
  6. Nads
    Nads
    from Hypocrisy
    Ever since man made the internal combustion engine tinkerers have looked for ways to extract silly noises out of it.
  7. petritl
    petritl
    from Marion, TX
    My dad has one on his A. We called it the chicken whistle, it sounds best at low RPMs and high load like climbing a hill or taking off from a stop.
  8. F&J
    F&J
    Supposed to have a lever and on/off valve. Looks like they brazed over where it was.
    That's a shame because that is a very early one. they go for good money depending on the plug thread, some thread sizes are rare. 18mm,14mm, as well as pipe threads
  9. Probably not very good I remember it on the motor once and remember it on his workbench for years :) Hes had the car since 75. I was like 5 when he got the whistle so memory is a bit fuzzy
  10. Splinter
    Splinter
    Straight pipes are my favorite......
  11. Phil1934
    Phil1934
  12. 49ratfink
    49ratfink
    hmmm... wonder what one would sound like on a smallblock spinning 7000 RPM.s
  13. shinysideup
    shinysideup
    from ruskin, fl
    Thats an "explosion whistle". It is missing the valve for momentary operation.
  14. shmoozo
    shmoozo
    from Media, PA
    Imagine, if you will, a flathead engine with dual plug heads, ...
    ... but with just one set of plugs. In the other plug holes are a collection of valve operated whistles of different pitches, and some means by which to sound them each individually.
    If they were properly tuned, you could play them like a musical instrument; an 8-note internal combustion calliope, if you will.
    Good idea? Bad idea?
    You be the judge.
    :cool:
  15. I could have bid on an air compressor last week made from a Willys 4-cylinder engine - two cylinders ran, two compressed air. So apparently you could run an engine with one of these in it at least enough to scare folks.
  16. junkyardgenius
    junkyardgenius
    from Kernow
    Saw something like this in a parts book the other day said it was used to find TDC.
