sagging 3 window doors ?
Discussion in 'The Hokey Ass Message Board' started by ago, Apr 18, 2013.
  1. ago
    ago
    from pgh. pa.
    32 original Ford 3 window coupe. All new dovetails and hinges are all tight. I know they are bolted to wood, in really good shape. Any ideas to pick them up a bit? shimming, jack, heat etc. ?
    Ago
  2. alchemy
    alchemy
    Cable and turnbuckles from the backside of the post down to the subrail over the axle?
  3. bgaro
    bgaro
    i'd jack the door up, but i'm a barbarian and don't own a 32 3 window.
  4. dolsen37
    dolsen37
    from Nebraska
    I would try shimming rear of the body. I have a 3 window that doors fit perfect and when I removed body for paint doors sagged at front right away. Placed back on frame and shimmed rear and doors fit good again.
    Good luck
    Dan
  5. ago
    ago
    from pgh. pa.
    Would shimming the rear make the front go lower?
    Ago
  6. ago
    ago
    from pgh. pa.
    Good info, will try it.
    Ago
  7. lucky ink
    lucky ink
    I'd say shimming plays a big part in picture especially Henry body and after market frame.. Or even a reworked Henry frame. Or even wood kit could be an issue ..
  8. 325w
    325w
    You can shim behind the A pilar and lift the back of the door some. I think it depends in how much you need to bring the back of the door up. One of the magazines did a real good article some years back on shimming.
  9. aaggie
    aaggie
    If you work on old cars a lot you realize that shimming between body and frame is a skill you need to learn. Old cars, especially Fords used blocks of hardwood as shim material and over the years it rots away and compresses. If you take the body off to rebuild the frame you need to label the shims and measure the thickness. After re***embly it starts with getting the door gap at the "A" pillar right then working your way back to the rear until the gap between the back of the door and body are acceptable. Next is getting the cowl to hood right and finally the front of the hood to grill shell. It can take several days but the overall look of the finished product is worth the effort.
