This transmission came from a 1966 Chevy C10 with column shift. This is the NON overdrive version. The input shaft has 10 splines and 1 ring. It shifted fine when it was removed from my truck and should shift fine in yours if your linkage is in good shape and adjusted properly. But, it could probably use a good overhaul. $150.00 and she's all yours. I am located in the Chattanooga, TN area.
