Technical saginaw parts source?
Discussion in 'The Hokey Ass Message Board' started by 1pickup, Feb 17, 2026.
  1. 1pickup
    1pickup
    I've dug around here and the web and I'm coming up empty. Looking for new input needle bearings (14, I think) for a 4 speed (same as 3 speed, I ***ume). I'm replacing the front bearing and using new seals & gaskets but can't find somewhere to get ONLY those needle bearings, without buying a complete small parts kit. Surely, there has to be someplace that carries just those. Sorry, I don't know how to post a video, but here's what I'm trying to fix:
    https://photos.app.goo.gl/vC5cPH139beFdVj16
  2. K13
    K13
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Both of these sources have been good to me for Saginaw parts. IMG_5335.jpeg IMG_5336.jpeg
    5window, 42merc and alanp561 like this.
  4. 1pickup
    1pickup
    Everything looks really good inside, just didn't like the "wobble" of the input shaft. Found those at a local (sort of) trans shop. It's probably the input bearing. Wow. Found everything from $10-$80 on those. The trans shop guy said don't skimp on that bearing, so I think I found a quality one at a decent price.
    Johnny Gee likes this.
  5. Corn Fed
    Corn Fed
    So did you buy some from the local guy or did you get them from somewhere online?
  6. 1pickup
    1pickup
    @Corn Fed Got the needle bearings at Badger Transmission in Madison, WI. He had some leftover (new) parts laying around. Ordered gaskets/seals kit online. Waiting to hear back about the front bearing. Apparently, there are a couple different ones that will work. Some have more ball bearings in them than others. I was set to buy a cheap one, until I talked to the ****** guy. He said to get a good one. He also said that was most likely the problem I was having. I found a 1207SL which is the better one and supposed to help with the wobbly input.
  7. 5window
    5window
    ****** dude sounds wise. Bearings are not a place to go cheap.
  8. Damon777
    Damon777
    For future reference, Zumbrota Drivetrain in Zumbrota, MN has a lot of individual parts for old manuals available (bearings, seals, some frictions, etc.).
    At least they did when I was working there a few years back.
    1pickup and Driver50x like this.
