Technical Saginaw to T5
Discussion in 'Traditional Customs' started by anothermoneypit, Feb 25, 2017.
  1. anothermoneypit
    anothermoneypit
    from CT
    I am swapping a saginaw out for a T5 1993 vintage. It has the Ford bell housing layout. Is there an adapter for this?
  2. bjinx
    bjinx
    There is a member on here named INLINE that makes T-5 Adapters for several applications. He advertises in the "Parts for Sale" forum on here. Check him out, very good guy to deal with. I bought an adapter from him, good price and received it in about 10 days.
  3. RICK R 44
    RICK R 44
    Try Modern Driveline Inc Tel 208 453 9800. There are 2 different input shaft lengths on the Ford T5 trans. The 4 cyl trans is about 3/16 of an inch longer and requires a spacer, available from Modern
  4. anothermoneypit
    anothermoneypit
    from CT
    Thanks fellas. It is a GM S-10 T5, in 93 they went world cl*** with ford housing and bolt pattern... hoping I can use it.
  5. bjinx
    bjinx
    INLINE makes an adapter for your needs
  6. nobby
    nobby
    hello, do these have a 26 splined input at 1 1/8 inch girth
    are the inputs the common 9 1/4 length
    do the splines happen to be in the same place as say
    a t5 v8 Camaro / v8 mustang
    oh and what is the pilot bearing bore for it
    or in other words.......
    could I get one of these, then using a fox bell and a 302
    simply buy a 10.4'' Camaro clutch friction disc and bolt it all together.
    thanks
    does the input look like this
    -the tvr version with the 9 1/4 input 26 spline and 1 1/8 girth
    p.s. if you end up buying a chevy wc case and swapping the bits in, that later s10 tail
    locates the speedo drive 2 inches forwards
    http://www.ebay.com/itm/GM-S10-21-t...ash=item3d21b8458f:g:ar0AAOSw3xJXoAUo&vxp=mtr
    in a word.. no
  7. Mr48chev
    I spotted that unit the other night when I was trying to find an adapter like the one I have that came with my flathead with the hogshead Came up with this Ebay one
    192011901596
    But I'd think that they are available from a lot of sources .
  8. Imwalkin
    Imwalkin
    from Tucson, Az
    I have an Inline adapter for my s10 t5 world cl*** transmission. It worked well and a great guy to deal with.
