Hot Rods saginaw
Discussion in 'The Hokey Ass Message Board' started by dondogarage, Apr 7, 2016.
  1. dondogarage
    dondogarage
    from richmond
    working on my 32 studebaker coup used a 215 ci. olds with a saginaw 4 speed. there is a reverse switch on the rear of trany for backup lights now I see there a single termal on the front. dont have any idea what it is for any idea thanks
  2. samurai mike
    samurai mike
    wasn't that something to do with putting it in reverse before you could start the engine?
  3. 56sedandelivery
    56sedandelivery
    It's a timing issue deal for meeting EPA regs; transmission controlled spark system (TCS) or combination emissions control solenoid (CEC), and controls the vacuum advance in high gear, depending on the year. The start issue was in the clutch pedal linkage; it did't matter what gear it was in. I am Butch/56sedandelivery.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    TCS switch ? It was used in later smog equipped cars. It sent a signal to say it was under a heavier load while in 3-4.
  5. 56sedandelivery's description of the TCS system is correct. First year about 1970 or 71
  6. dondogarage
    dondogarage
    from richmond
