salisbury rearends
Discussion in 'The Hokey Ass Message Board' started by aircoup, May 8, 2013.
  1. aircoup
    aircoup
    salisbury rearends , are they reliable never had one but am considerin tradin a nine inch: for a complete one which mine isnt :confused:
  2. banjeaux bob
    banjeaux bob
    from alaska
    Keep the nine inch.Salisbury is the British version of ****er.Might find it hard to find parts to service the internals on the Salisbury.
  3. Wardog
    Wardog
    The Australian Salisbury's are ok if you have a ten bolt but I would never trade one for a nine inch. The nine inch is the standard as far as non banjos go and still very traditional. Salisbury's can be hard to change ratios as the carrier is part of the housing and the open centre rear ends don't accept the lsd centres
    Sent from my DROID device using the TJJ mobile app
  4. Weasel
    Weasel
    Hundreds of thousands of Jaguars can't be wrong....
  5. aircoup
    aircoup
    im missing alot of parts for this and the bearings have been welded on the shafts so all i have is a housing and a set of gears , hard to find everything else axles ,backing plates , ect
  6. Wardog
    Wardog
    Neither can millions of full size V8 ford cars and trucks.
  7. Hefty Lefty
    Hefty Lefty
    Dana (44, I think) ring and pinions fit the Jag rear end, a fact a surprising number of jag "mechanics" don't know. I think the Salisburys in Land Rovers will take a Dana ring, pinion and diff too.
    But a 9" Ford is a better rear end than any of these.
  8. aircoup
    aircoup
    guess id better start looking for axels and backing plates huh
  9. junkman8888
    junkman8888
    Greetings! The big advantage for the Ford 9" is adaptability: If you want to race, in a few minutes you can swap in a pumpkin with some serious gears, if you want to cruise, swap in a pumpkin with some "legs". Because of this versatility, the "9" is also usually cheaper to build.
  10. aircoup
    aircoup
    this is gonna be a mostly street driven 56 , with a 302 and a c4 behind it stock for the most part ,
  11. aircoup
    aircoup
    well after doing some research this rearend turns out to be a early 60- 66 galaxy 31 spline rearend yep im keepin it ,,,
  12. 45_70Sharps
    45_70Sharps
    And as a guy that has had many rovers from '52 to '99 I can say that rovers are great rigs with many typical British problems. The running gear is always rock solid though.
    That being said, the 302 going into the 56 is capable of putting out a lot more power than the rovers make.
    The 9" is a much better choice for a street rod.
  13. aircoup
    aircoup
    i agree ,, thanks
  14. savoyjfas
    savoyjfas
    from london
    im missing alot of parts for this and the bearings have been welded on the shafts so all i have is a housing and a set of gears[​IMG]
  15. aircoup
    aircoup
    waddya mean , savoyjfas????????
  16. Atwater Mike
    Atwater Mike
    I have a 9" **** in my F100, 5 on 5-1/2" pattern, out of a '60 Ford pickup. It was a 'bolt-in' for my '55.
    You probably should look for a '57 thru '59 Ford p***enger car rear, for the width.
    Don't set on a Ranchero or station wagon...they retain value, as the bearings and hub flanges are larger. (they use 1/2" bolts to bolt the backing plates to the flanges, easy to spot)
    Beauty of the '57-'59 p***. car is the spread of the spring pads. (bolt-in to your '56)
    I also have a 9-inch in my '54 Ford Coupe. (it's out of a '65 Ford pickup, but has been narrowed; strong for 406 and heavy duty top loader trans.)
    Use the 9 inch. They're still around...
  17. hoop98
    hoop98
    from Texas
    The Salisbury guys had to figure out how to make steel go farther by mounting the pinion and carrier directly into the axle housing. Then they worked on making steak go farther...
  18. aircoup
    aircoup
    theyre just not all that plentiful. this early 60,s one will do for me once i find the rest of the parts ,someone out there outta be able to help
