COE Salvaging a 38 Ford COE
Discussion in 'Off Topic Hot Rods & Customs' started by 65standard, Jul 21, 2013.
  1. mart3406
    mart3406
    from Canada
    I remember seeing a few of those
    roof-mounted "periscopes" on
    some old flatbed trucks, 'back
    in the day'. If you could find
    another one somewhere, it might
    be cool - just because no one else
    has one and you don't see them
    used on trucks anymore - to instal
    one rather than just filing the hole
    in the roof. If you checked on the
    American Truck Historical Society
    site (www.aths.org) and asked
    around there, I'll bet one would
    probably turn up and not be too
    pricy. The big cut-out where the
    back window used to be is a bigger
    problem. Going by the size of the
    hole, I wonder if the cut-out might
    have been for a sleeper that the cab
    may have had mounted on it by
    a subsequent owner, sometime
    after it's phone company service???
    Mart3406
  2. shopdawg
    shopdawg
    from alberta
    My dad had a c.o.e tow truck back in the day(70's) that had the mirror above your head and it was a series of mirrors that had a prism effect that kept the image behind you right side up and centered in the mirror you were looking up at. made it easy when you backed up. i"d like to look at another one to confirm what I remember.There's one on a truck near where I live in a plane museum but its going to take some convincing to let them let me look. a few years back I seen a conventional diamond t that had the box behind the cab,had a padded bench seat in it that was about 8in wide, didn't look very comfortable.
  3. biscaynes
    biscaynes
    more great fab work! :cool:
  4. Nice build so far. Hopefully see this one cruzing down I55 some day.
  5. shtterbug8
    shtterbug8
  6. Pops1532
    Pops1532
    from Illinois
    The cut out wasn't for a sleeper. It was for an add on crew cab that looked similar to a sleeper but had a bench seat and one door on the right side. They usually had a toolbox accessible from the outside on the left side below the floor of the crew cab. They were fairly common on phone company trucks. The add on crew cabs were usually backed up by a covered utility box. Sometimes the crew cab was integral with the box, sometimes they were separate.
  7. 65standard
    65standard
    I need to do a lot of mock up in order to get a good placement for the pedals. I started with making a seat riser out of 12ga. and a seat frame out of thin wall tubing.
    Once I have the seat frame, I can mock it up to see how much foam I need for it.
    Then I mocked up the floor and toe boards to get a feel where I want the pedals. I'm hoping for a floor mounted brake pedal with the booster and master under the drivers seat for access. Yes the engine will be in stock location for a true cabover.
    I think there will be enough room under the floor for the brake pedal mount.
    I really need to get the seat foam made to get an accurate feel for the cab, steering wheel, and pedals. Also have enough room for the chopped top. I will start with some 5" thick 2545 foam for the seat cushion. Not sure about the back rest foam yet.
  8. 65standard
    65standard
    Donor vehicle for the drivetrain.
    1973 Ford Econoline E-300 motor home.
    It is even a cabover setup with a 302/C6.
    It only has 49K miles on it.
    Wasn't easy removing the motor, but I finally got it out and in my garage.
    I am thinking about using a Ford AOD trans instead of the C6. Since I have 4.10 gears, the overdrive might come in handy?
  9. 65standard
    65standard
    Mid surgery transplant photos.
    I have to move the lower Chevy motor mounts rearward a few inches and modify the upper Ford motor mount in order to marry the parts together. All done with salvaged parts.
    I chose a Ford 302 and Ford AOD transmission for this Cabover because it is the largest motor that will fit in stock location and under the stock doghouse.
  10. T Hudson
    T Hudson
    awesome work, as always.
  11. UNSHINED 2
    UNSHINED 2
    You don't happen to have a rear sump oil pan?? That'll help ya set it a little lower for some more clearance?
  12. 65standard
    65standard
    Yes, the econoline 302 motor came with a rear sump pan. I got lucky there. I was prepared to swap to a rear sub if I couldn't find a motor with it already.
  13. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Very nice project! Love COE's. How are you handling ***ling? Keep it ***led as a 39, but carry the 87 ***le also to prove ch***is ownership?
  14. Racer29
    Racer29
    I like where this is going. I love wreckers. My Papaw(grandpa) was a wrecker man in TN. I used to help him alot and that's where my love for wreckers got started. He had an old '59 B-Model Mack for the big hauls. I've always wanted to build an old wrecker.
    It's crazy how in the first picture of this build the stripped cab favors the rear of a humpback sedan.
  15. 56 ford custom
    56 ford custom
    from Socal
    This truck is too cool! Great build.
  16. 65standard
    65standard
    No tilt cab here. I only mention that the telescoping steering connection would ease one issue with tilt cabs.
  17. 36 ROKIT
    36 ROKIT
    I think he is referring to ***le do***entation...
    Great build!
  18. flatford39
    flatford39
    I think he meant how are you "***ling" it. I would be interested as well because Illinois can be a pain in the ***. Will it be ***led with one of the donor cars or do you have a clear 38 ***le??
  19. 65standard
    65standard
    Oh, I misread ***le for tilt. I'm just using the 1938 ***le on the truck. I have no ***les for the vehicles used for donor parts. All of these vehicles are from my friends salvage yard. He must have all the paper work for those vehicles. Do I really need them?
    I saved all the vin numbers on the donor vehicles for my own records.
  20. flatford39
    flatford39
    I would do a search for Illinois ***le here on the HAMB. Your 38 ***le has probably been revoked by the state and you will have to apply for a new ***le. They are going to want to see serial numbers. something you don't have for the 38 ***le it sounds like. What they are after is the tax money they feel owed to them and they are basing appraisals on Barret Jackson prices. Be careful.
  21. killbilly
    killbilly
    Tony ,I am really liking your build on the COE,the 53 is fantastic also,I have a 55 C600 cab down in KY at my cousins barn ,future project also a 54 and 55 1st series at my place in Tn Nice work,I'm subscribed!
  22. 65standard
    65standard
    Motor mounts done. I have to pick up an AOD trans in order to finish the trans crossmember.
    Remounted the cab.
    A true cabover truck, a path others builders rarely take.
  23. vintagehotrods
    vintagehotrods
    Nice work and great use of salvage parts. COE project's are the best!
  24. T Hudson
    T Hudson
    Tony, look for a mid 70's dodge van in the boneyard, they had a master cylinder/booster that did a 90 degree turn on the firewall.
    *EDIT* Oops! forgot you were going under the floor.
  25. I've always loved Coe trucks there was a great one at lead east this weekend but as I took a close look there is no way I would fit in it, I'm 6'1" and it seems you need to be at least half a foot shorter to fit inside, is that true an all coe's
    Our only recourse on this road to hell is we're driving a firetruck!
  26. tedley
    tedley
    from canada
    I love do it yourself builds. This is going to work out nicely. Good stuff.
  27. Moondog13
    Moondog13
    Hey do you still have access to that 73 motorhome? I could use two small parts off of it. Let me know! :D
    By the way I'm loving this build! Subscribed.
  28. 65standard
    65standard
    Not sure if he didn't crush it yet. I will check tomorrow. What are you looking for?
  29. 65standard
    65standard
    These early Ford COEs seem to be the smallest ones. I'm 5' 7" and I built the seat to fit me with a 4" chop. Seat location is everything when it comes to drivers size.
  30. 65standard
    65standard
    The 1973 Econoline I used for the drivetrain had that 90 degree brake booster setup too.
