COE Salvaging a 38 Ford COE
Discussion in 'Off Topic Hot Rods & Customs' started by 65standard, Jul 21, 2013.
  1. spiders web
    spiders web
    I have a 49 ford COE that I will be starting soon and this build is great inspiration. Keep up the good work.
  2. 38-39 ford truck lover
    from duluth,mn
    maybe this will help
  3. 65standard
    65standard
    Thanks Bill and Brad for the pictures. It looks like the lower main body brace is exposed at the door bottom. I would have thought that it was wrapped by the inner rocker panels.
  4. legion
    legion
  5. 38-39 ford truck lover
    from duluth,mn
    your welcome, does that door look as solid as we thought ?.....
  6. 65standard
    65standard
    The door is very solid, only a minor blister on the lower outer skin. Thanks for helping me get some of the much needed parts to salvage this old Bell Company truck.
  7. rusty1
    rusty1
    nice work on your truck(s)...hope to see em around as I'm not far from you.
    ...here's some COE's I've drawn...
    OahuEli and bengeltiger like this.
  8. T Hudson
    T Hudson
    Awesome work Rusty, you too Tony.
  9. shadams
    shadams
    Dang Rusty1, you need to post up some more stuff like that, those are bad ***! Great work!
  10. rusty1
    rusty1
    ...check out the past & future Friday Art Shows, I post on there each week.
    these are "woodart", hand-drawn on 1x10 white pine boards, cleared with satin varnish...
    they are about 32" each.
    thanks fer the comments!
  11. 65standard
    65standard
    The Holmes wrecker bed is just about finished. I still need to find either 1938 Ford or 1938 Chevy pickup rear fenders for it. The floor will be wood except where it angles down at the back will be stainless diamond plate.
    I will have to order the diamond plate. From the end of the inner tubs to the tail panel will be the plate.
    volvobrynk likes this.
  12. JOYFLEA
    JOYFLEA
    38 ford pu fenders are 38-41 . I have a pair that are rough if interested pm me . Blue
  13. JOYFLEA
    JOYFLEA
    Tony , here are some pictures of the fenders . They are rough but after seeing your metal skills no problem . Let me know and if you want to talk about them pm me your number , Blue
  14. 54fierro
    54fierro
    from san diego
    Great build, I like seeing all the detail and thought that went into every step.
    Looking at your thread reminds me of when my dad used to say he was not a body man, he was a metal man.
    Can wait to see more
  15. czuch
    czuch
    from vail az
    Good grief, I am in awe.
    I may never be able to shake your hand, but if you PM me I'll send a check and buy you a beer.
  16. fairlaneranch
    fairlaneranch
    Man! You have some drive man! GO-GO GO!!!!!
  17. killbilly
    killbilly
    Tony,is that a HF english wheel?I have been looking at them. Have you used it much yet,and what do you think about it? Phillip
  18. JOYFLEA
    JOYFLEA
    Got a hf wheel . works fair but with 18g I put a support on top and sides 100000% better .
  19. 65standard
    65standard
    Yes, it is an older Harbor Freight Ewheel. Like most import Ewheels, the biggest problem is yoke slop. You can eliminate 95% of the slop by re-milling the V-grove to a 1/2" deep channel a fraction wider than the locking bolt. Then grind the nose off the locking bolt and run it in as fas as possible into the new channel without locking it. This will make it feel like a new machine.
    The other issue is the quick release. There is no stop pin for the level. It just goes round and round. I don't worry about this as I never use this feature. But some guys drill a hole and insert a stopping pin at the upper limit and one at the lower limit of the quick release.
    The newer HF Ewheels have a completely different quick release and yoke than my old HF Ewheel. Maybe they improved these issues?
  20. 65standard
    65standard
    Anyone know what the hell I'm doing here?
    Chopping the top 3.5" straight down. Which means 3.5 in the rear and 3.75 on the A-pillars because of the angle. Also need to fix the cut up and rusted out roof.
    Setting the roof back on to get a look at what is needed to align it all back up.
    The roof will need to be split and stretched 1.25" to get the B-pillar re-aligned. It will also need to be split in the rear and widened .75".
    N[​IMG]
    The A-pillars will need lots of work to get them flowing back together.
    The A-pillars on the COE cab taper as they go up. This makes it more challenging than say a regular 1938 ford cab. My plan is to get these A-pillars aligned up and tacked together first.
    Here is the right hand A-pillar
    Now, carefully aligning it back together
    It is slowly coming back together.
  21. xtremek
    xtremek
    Ok, now you're just being mean.;) Tease us some more.:p
  22. You are the ultimate recycler and fabricator.
    Amazing project. I congratulate you on this project.
  23. jfreakofkorn
    jfreakofkorn
    another one being saved ... some really nice fabrication skills and cant wait to see the updates =)
  24. 38-39 ford truck lover
    from duluth,mn
    tony, are you going to roll out a new roof, our do you have a section off a truck cab . ? ....talk of your H F english wheel, an inner tube works great on that upper wheel...it was a help on mine..
  25. 65standard
    65standard
    Brad, I have a roof skin from a '38 donor cab. After the chop is done I will cut out the center of the roof and weld in the donor skin. It is easier to just weld around the perimeter than to quarter the roof and fill in strips all the way across. Too hard to reach with hammer and dolly that way.
  26. King ford
    King ford
    from 08302
    Greetings tony I think I have a couple of photos of what you were looking for,they are in my album under "my fleet" if you need more let me know ,I love your build,(ford in a ford ,god bless you, rodent motors infest so many fords ! True cabover ,really like the wrecker body, gonna build one for mine) now my questions, what do you weld your tin work with,( looks like mig?) where did you get your shirking disk and briefly how do they work?
  27. Subscribed!
  28. 65standard
    65standard
    I use a Lincoln PowerMig 350. Tack weld every inch and then weld one inch at a time with a magnetic copper backer. The copper acts as a heat sink and prevents burn through. I'm a member of Metal Meet and the founder Wray Schelin makes and sells the shrinking discs I use. He also offers a DVD showing how it works and how to use it.
    A little more progress getting the top back together.
    And the donor roof skin.
  29. afaulk
    afaulk
    Your build is motivational! I especially like the bed. When I get rid of a couple of projects, I hope to find a late 40s Chevy COE for my next NEXT project. Keep up the good work.
  30. King ford
    King ford
    from 08302
    Thanks for the info how do I contact wray to purchase one?
