Sanblasting Vs. Acid Dipping (COST?)
Discussion in 'The Hokey Ass Message Board' started by Garage Concepts, Oct 17, 2007.
  1. Garage Concepts
    Garage Concepts
    I've been working on my car from time to time. Shaving stuff off as i take it apart. I wanted to get some opinions on weather i should sandblast my car or acid dip it and about how much will it normally run?
    Thanks in Advance...
  2. squirrel
    is there a dipping place near you? can you blast it at home, or have to send it out? how are you gonna transport it? how rusty is it? how far apart are you going to take it? what kind of car is it? lotsa variables here...help us out....
  3. Garage Concepts
    Garage Concepts
    No dipping place near me what so ever, that i know about. I would like to send it some were just b/c of the big mess. The car is in pretty good shape with some minor surface rust inside. I'm just fixing the car up to keep for life and maybe p*** it on to my kids or grandchildren. 1949 Lincoln 2Dr...
  4. OutLaw
    OutLaw
    Your best bet is to Blast it with Soda, You'll get great results witth destroying your car. Sandblasting is very very bad for your car, I've seen perfectly good cars turn to **** in an instant.
  5. jonzcustomshop
    jonzcustomshop
    I would go with the soda too.
    you end up cleaning up the sand for years it seems like, and you run the risk of getting warped panels.
    I worked on an acid dipped car once (57 chrysler 300) It was so neat, the good panels made it look like we were in 57 on the ***y. line!
    However a friend pointed something out.
    when the manufacturers put a car together, they might, say on an inner rocker for example, put seam sealer, or body putty in a gap or on a seam... acid dipping removes all of that stuff. there would be no way to get to it, unless it was all apart again.
  6. 29bowtie
    29bowtie
    Most dipping processes are not acid,but reverse electrolysis therefore they don't remove good metal or thin the good metal.Acid dipping was used years ago by Nascar racers to illegally lighten their cars.Not what you want for a hot rod project.
  7. Garage Concepts
    Garage Concepts
    Blast it with soda:confused:
  8. squirrel
  9. Stroked
    Stroked
    from DFW, TX
    When blasting body panels, baking soda does not build up heat like sand. This means you won't have the warpage of body panels ***ociated with sand blasting.
    As for costs, I actually called a few places here in DFW last week about this.
    I have not found a soda blaster yet, but to sandblast it is $150 per hour. Before they start work they will make you sign a waiver stating that you understand the risk of warping that comes with using sand on large body panels.
    There is place here in DFW called Metal Rehab that does dipping. From what I remember, their prices ranged anywhere from $1500 to $3500.
    - Matt
  10. officerfalfa
    officerfalfa
    I paid about $1K to have my A coupe blasted, prepped, and primed. Well worth the money.
  11. ig'nant
    ig'nant
    We're painting with some pretty broad strokes here, when it comes to blasting.
    There are tons of different media, and lots and lots of variables. I'm not an expert on the subject, but I've had parts sand blasted, and I've spent more than a few hours in the hood myself. From my experience, something like starblast works wonders. Had no issues with warping whatsoever.
  12. Garage Concepts
    Garage Concepts
    Sweet, Thanks Matt.
  13. Garage Concepts
    Garage Concepts
    Anybody know of any shops in Orange County, CA?
  14. 29bowtie
    29bowtie
    Try a google search for non-destructive rust removal,there are many industrial uses too,so most locations have someone.Redi-strip is a national franchise name that we have up here.
  15. 28 chevy
    28 chevy
    from NE Pa
    Can I do soda blasting with my sand blasting equip? Is it more costly? Is the soda easy to get. Can it be recycled or is it single use. Home shop friendly? Any suggestions, I would like to try it.
    Jim
  16. 29bowtie
    29bowtie
    I don't believe,conventional sand blasting equipment will work.
