Hot Rods Sand blasting, DIY cabinet
Discussion in 'The Hokey Ass Message Board' started by Mike Colemire, Nov 22, 2020.
  1. Mike Colemire
    Mike Colemire
    I know several of you on here have made their own sand blasting cabinet, just wondering what kind of gun you purchased and how good does it work? I'm having problems with the one I built, it always had problems with the courser material but now it's quit altogether. I use a cheap gun off ebay and in the 4 yrs I've used it I did replace the gun once. I emptied it out and put 3 new bags of the metal grit or whatever you call it, in it today and still nothing. It feeds from the bottom and I drilled a 1/4 hole in the top of the fitting the hose goes on. It's a 1/2 in ID hose and the air hose to the gun is 1/4 in. Should the hose be bigger for the media to come through? I thought maybe that's why I had trouble with the larger stuff. I can get some pics of the set up I got if it will help, just thought maybe you guys had some pics or advise on your set up.
  2. 31Apickup
    31Apickup
    Check out TP tools, a lot of people retrofit their HF cabinet with the TP gun, that’s what I did and it works great.
  3. flatford39
    flatford39
    ^^^This^^^
  4. Mike Colemire
    Mike Colemire
    Good looking gun and it's only $69 plus I see they have a tune up kit for it also. That makes it even better.
  5. treb11
    treb11
  6. ekimneirbo
    ekimneirbo
    There is a video out that shows a simple modification to the suction hose (metal tube) that really makes a difference. I fought with my sandblaster for a long time before finding out about drilling a hole in the right place. Big difference. I use the smallest coal slag and buy it at Tractor supply.
    anothercarguy likes this.
  7. bill gruendeman
    bill gruendeman
    I agree with TP tools I used their gun and pick up tube and it works great.
  8. lippy
    lippy
    from Ks
    Build your own if you want but the store bought TP setups are the way to go. Save yourself the headache and buy a nice TP cabinet and vacuum and get her done. Lippy
    Truckdoctor Andy likes this.
  9. I couldn’t agree more, it’s the best piece of shop equipment Dad and I have. We bought one on the big ones that will fit a tailgate inside. Mom was terrified Dad would have a stroke outside in the sun when sandblasting. It was actually her idea to buy it.
  10. Budget36
    Budget36
    Links to the TP guns?, do we buy directly through them, or? ***ume Nozzles are available for the guns as well?
  11. leon bee
    leon bee
    I bought one glove from them, they sent a nice catalog along.
  12. 31Apickup
    31Apickup
    You can buy direct from TP, also bought Kirker Enduro epoxy primer thru them.
    Budget36 likes this.
  13. alchemy
    alchemy
    I bought a used TP (Skatblast) blasting cabinet a decade ago and it's the best piece of equipment I own. I always order all my supplies directly from TP. I buy sandpaper from them too.
  14. ekimneirbo
    ekimneirbo
    Here is a video on upgrading a HF cabinet and blast tube. The HF cabinets are decent size. The smaller ones are a PIA as its hard to manuever the hose. Building a wooden cabinet will work if you want something larger. One good mod is to buy a roll of mylar and mount it next to your sight window. Kinda kinda like a sideways toilet paper roll. Then run it under the gl***. It will protect the gl*** and when it gets cloudy, just loosen the gl*** and unroll a little more mylar. This tube modification in the video works good.
    Dak Rat likes this.
  15. Jay McDonald
    Jay McDonald
    built a cabinet 25 years ago with a tp kit, easy to get consumable parts and works perfect, get the foot pedal controlled gun, it is a game changer
  16. Joe H
    Joe H
  17. ekimneirbo
    ekimneirbo
    For what one of the HF blasters costs, it would be better to start with one of the larger ones (not the table top) and give it a try. You can often find used ones, but watch because some people want more than a new one costs r the gun is screwed up. They are about $190 and I think you can use a 20% off coupon. You can't really buy the individual components to outfit a home made one for that. Then if you need a larger one, build one and use the components from the HF unit. Be sure to do the tube modification and I think you will like it.
