sandable power powder coat primer ?
Discussion in 'The Hokey Ass Message Board' started by divco13, May 14, 2013.
  1. I have rust pitting, on My wire wheels. Going to strip and re power coat them.
    Is there a sandable powder coat primer ?
    Would like to sand blast , and resurface the area before a complete power re coating.
    I would think, the primer would have to a higher cure temp, as to be stable, for the application of the final powder coat, at a lower cure temp.
    Googled,sandable/surfaceable power coat primer, with no luck !
  2. bgaro
    bgaro
    i don't believe there is such a thing, but i've been wrong before.
  3. HOTRODPRIMER
    HOTRODPRIMER
    I've never heard of powder coat primer,,,best thing to do is take the wheels to the guy in your area that does powder coating and get his opinion. HRP
  4. bpg_austin
    bpg_austin
    from Austin, TX
    Yes, there is a sandable PC primer. Its called 'KL Primer' Its pink, and your local PC shop should know how to use it. They simply shoot it, let it cool, sand, then shoot color. (or, multiple rounds of KL if required) There might be more sandable PC primers, but KL is the one I'm familiar with.
    Big blemishes can be filled with lab metal or equivalent PC friendly metal filler. Hope this helps.
  5. mashed
    mashed
    from 4077th
    Sandable primer on wire wheels! You are a glutton for punishment.
  6. bpg_austin
    bpg_austin
    from Austin, TX
  7. Pitting is only on the Wheel shell.
  8. Thank you for the perfect solution for my request. After looking in to it, I found there is a replacement KL, it is now call RL. KL is no longer made.
    bpg_austin Thank you for your time, and effort. PERFECT ANSWER !
    http://www.propowdersupply.com/catalog/primers/rl-primer-replaces-kl-primer
    Again thank :you Bob
  9. chubbie
    chubbie
    Yes there is , i use eastwoods black
  10. Use Zinc primer powder if you have pitting. It will fight against rust better. We use it sometimes to fill in deep pits. Done some 46' Ford bumpers one time, worked good, but we also used a DA on it to sand it. You can also use JB Weld, make sure it's the 24 hour cure, not the 5 min stuff. The 24 hr cure will handle 600 deg. Works great but it's a ***** to sand!
