Sandblast or dip?
Discussion in 'The Hokey Ass Message Board' started by 53RedRam, Apr 23, 2008.
  1. 53RedRam
    53RedRam
    from Bend, OR
    I am just begining a frame off on a 53 Dodge. I wonder if it is better to sandblast or dip. The dipping process seems to be 1. paint stripping and degreaseing using a hot caustic bath, 2. rust removal in a cold bath, 3. use iron phosphate to neutralize and seal the metal.
    Also, What about a ceramic spray coat that is supposed to insulate and reduce sound? Any advice greatly appreciated.
  2. Hot Rodz R Us
    Hot Rodz R Us
  3. Corn Fed
    Corn Fed
    I've had it done both ways. I won't dip anything that has a seam or fold in it again. The chemicals are near impossible to get back out and can cause lotsa problems later.
    Find a good blaster who knows how to properly do sheetmetal.
  4. Abomination
    Abomination
    :eek::eek::eek:
  5. Rossco
    Rossco
    from SinCal
    Sandblast it, if possiable ask what media there using. PMB type 5"plastic" is good, it doesnt streek, most gl*** and ceramics are good also but not as forgiving as PMB. When there done blasting they should do a distilled wash or bath, then cook the frame to remove any residual mositure. Chemical conversion coating. Then powder coat that baby.
  6. LabRat
    LabRat
    Yes , go with SODA .... less mess , it just washes away . can be done in your driveway .
  7. <FANG>
    <FANG>
    from W.L.A.
    Dip get's all the rust
    Blasting get's only what it hits
    check here for companies that specialize in Auto paint stripping
    there was a place in Santa Ana Ca don't know if they are still around
    Redi-Strip was the name of the company I think it was a franchise
    might be one close to you
  8. toddc
    toddc
    Blast it. The chemicals from dipping ( acids and bases ) will stay in all of the tight overlaps. Until they rust out:rolleyes:
  9. Brad54
    Brad54
    from Atl Ga
    What issues specifically did you have? I've heard guys say they've had issues, but I've never heard specifically what they are.
    What kind of "after" treatment was done?
    I'd like to learn all you can tell.
    -Brad
  10. HemiRambler
    HemiRambler
  11. Keith123
    Keith123
    I just took my 1955 Chevy to them.
    Strip Clean Co.
    Santa ana, CA
    714 775-7797
  12. Weasel
    Weasel
    <fang>
    Yeah like a guy in OR is going to have his car shipped to SoCal for stripping and then back to OR - add say $2500 to the bill - WTF.:eek::eek:
    Soda blasting works great, but if heavy rust then blasting, but only by somebody who knows what they are doing - the big danger is too much heat build up which warps panels and they are nigh impossible to get straight again. I have just stripped a body this past weekend using 3M Strip It purple discs and a Makita GV 5000 sander. Took the weekend to do and got all but the small nooks and crannies. Do it outdoors as it is messy - dust everywhere - wear a respirator and safety gl***es as chunks of the Strip It disc fly off.
    Chemical strip probably will come back and haunt you unless you get all the chemicals out of the seams yourself and I would not recommend it. I have had all three procedures done and soda is my preferred option if I do not do it myself. My 0.02c .....
    </fang>
  13. 49anglia
    49anglia
    Another NO to dip here.
    A friend has his porsche dipped recently. Its been sat in a dry workshop in E coat and all the seams now have rot where the chemicals sat. Also, you vet little air pockets in high up places that dont get touched by the chemicals.
    Dipping is alot of money and prety much ruins the body.
