Projects Sandblasted body epoxy or leave?
Discussion in 'The Hokey Ass Message Board' started by Levi schilz, Feb 4, 2025.
  1. Levi schilz
    Levi schilz
    I just sent my 29 off to get sandblasted. I live in denver so it's fairly dry unless I run heat this time of year then I get moisture. I'm concerned about rust after getting it back from the blaster but have patching and dent work to still do. Should I epoxy primer everything then maybe wirewheel it off where I need to do repair work later? It's going to take some time to fix everything so not sure what is the best option. Obviously just leaving it bare would be easier to address the metalwork.
    Also wanted to say I'm new to the group but the conversations here are always pretty good for this kind of work and car style and appreciate everyone's comments on here!
    Thanks!
    Levi
  2. TwistedMetal
    TwistedMetal
    from Wisconsin
    Welcome. I used a metal prep right away on bare metal to keep it from rusting. Then I washed that off with soap/water, sanded, then wax and grease remover and then epoxy primer. But I stripped mine one panel at a time. Now mine is all in epoxy primer, I will start the metal work and patching and epoxy prime again. I'm slow.
  3. Bandit Billy
    Bandit Billy
    It will rust, and in my experience, rust quick. Compressed air often has water in it from condensation, if it does you metal will start rusting on day one. If you doubt that take a piece of steel, toss it in your blast cabinet and after cleaning it, take a propane MAP gas torch to it and watch he water vapor burn off.
    After blasting I clean, heat, epoxy primer (while it is still a bit warm) and store indoors. Epoxy primer alone will not keep the metal from rusting under neath it. It will slow it, but not prevent it. I recently epoxied bare steel on my daughters truck that she is driving this winter up on the mountain. But I plan to paint the truck this spring so it should be fine for the limited amount of exposure it will face this winter. Otherwise I would get to strip the primer and remove the new rust that formed like I had to do with my 41 PU cab. Rust never sleeps.
  4. Happydaze
    Happydaze
    https://view.publitas.com/ims-catalogs/products/page/1
    You could do worse than to look into Industrial Metal Supply descaler and degreaser. It removes and prevents rust. It leaves an easy to wash away coating on the surface.ive overcoated it with Gibbs Brand when it's being left for a considerable time. No good for exposed outdoor storage though.
    Chris
    gimpyshotrods likes this.
  5. goldmountain
    goldmountain
    It is pretty dry where I am and rust hasn't been a problem.
  6. Hollywood-East
    Hollywood-East
    DA as much as you can..
    Whatever direction you choose.
  7. In_The_Pink
    In_The_Pink
    Watch this, very good advice, IMHO:
    tomcat11 likes this.
  8. Levi schilz
    Levi schilz
    Ugh.. now I feel like I should of waited to blast. It's also suppose to be in like the 30s this coming week. Any better options than epoxy primer? Thanks for everyone's feedback appreciate it
  9. Rocky
    Rocky
    Classified Editor
    I used epoxy primer on mine after chemically stripping. Drove it around for about a year as-is and got invited to show the car at World of Wheels show. It snowed and turned to slush move-in morning so to keep dirty slush and black **** out of the porous primer, I waxed the whole damned car! I have no plans on finish paint so I just touch it up occasionally with wax and it's looked like this for 3 years. Low maintenance! 34atgarys2020.jpg
  10. Levi schilz
    Levi schilz
    Haha that's cool rocky
  11. I’d pick out an epoxy
    look up the tech sheet and follow the instructions
    then go from there
  12. spudshaft
    spudshaft
    I live in a completely different environment, but I think you should put something on it. If nothing else everywhere your skin touches it or sweat drops hit it it will rust.
    Just Gary likes this.
  13. alchemy
    alchemy
    My garage is heated (bare minimum sometimes in the winter), and I live in Iowa where the temperature fluctuates between -10 to 100. Our humidity fluctuates between 10 to 100 also.
    I have a variety of bare metal panels in my garage that look the same as the day I put them there. Some blasted, some dipped, some sanded. I think the key is to not touch them a lot.
  14. rusty valley
    rusty valley
    Hope you have a good blaster so its not all warped to ****
  15. Levi schilz
    Levi schilz
    Yeah I was worried about panel warping also. They have been blasting for 25 years so hopefully they do decent.
  16. F-ONE
    F-ONE
    from Alabama
    Some of the better restoration blasters will blast and prime. This way it comes home primed.
    Is this an automotive blaster or an industrial blaster?
    Whatever you do, get some epoxy primer on it.
    I have seen several blasted cars just left to ruin.
  17. oldiron 440
    oldiron 440
    I would put two wet coats on the inner and bottom of your project and one coat on the outer body itself. Epoxy primer does not need etching primer before applying the epoxy, I would sand the outer body with 80 grit on a DA and then go directly with epoxy. Epoxy was formulated for sandblasted metal with no coatings.
  18. TwistedMetal
    TwistedMetal
    from Wisconsin
    If you can't get to epoxy primer right away why wouldn't you just steel wool some metal prep on the panels? You can buy it at Home Depot. This should also remove any light surface rust.
  19. larry k
    larry k
    Poxy it man ! Always proxy it !!!
  20. Budget36
    Budget36
    So is it 80 grit with a DA on bare metal before epoxy priming?
  21. Most of the tech sheets I’ve read say 80-sometimes 180 on bare steel
    120 seems to be a happy middle
    tb33anda3rd and Budget36 like this.
  22. 57 Fargo
    57 Fargo
    Read the tech sheet, some epoxy primers will cover the blast profile
    anthony myrick likes this.
  23. 1971BB427
    1971BB427
    from Oregon
    Any major bodywork or rust repair I do before I strip the whole body. Anything minor I leave for later. I always shoot bare metal with epoxy primer/sealer as soon as I can. Then do whatever minor bodywork it needs over that.
    2OLD2FAST likes this.
  24. K13
    K13
    Really dependant on your location. I can leave bare steel in my garage for years and it won't rust. You live somewhere where it is humid and that doesn't fly.
    If you are getting stuff back from a professional sand blaster and it is rusting because they have water in their lines and it has been left on the metal you need to find a real company to deal with. There is zero excuse for a reputable blaster to not have the proper equipment to do the job professionally and that does not include water in their air.
  25. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    When I was a dumb kid (19 or 20) I rented a sand blaster and stripped my whole '55 Chevy. My buddy comes over and asks me what I'm going to do to keep it from rusting. I said I'd fix the holes and then get it painted. He said, "I mean today!"
    "Duh, you mean it's going to rust that quick?"
    Luckily his dad owned a production paint facility. We towed the car to his house, ran to the shop to get supplies and sprayed it in their carport. Aircraft Critical Corrosion Green!
    That was the best foundation and absolutely kept it from rusting.
    Don't know if that is still available but it certainly is worth looking into.
    Now, I'm just a dumb old guy!
    klleetrucking and neilswheels like this.
  26. neilswheels
    neilswheels
    from England
    I think that might be the really good green etch you used to be able to buy, cant get it here now, banned (the UK) but great stuff. I've had a mag trans case in green etch for 15 plus years, no issues
  27. neilswheels
    neilswheels
    from England
    I'd epoxy it personally, better safe than sorry, its not porous and seals really well. You can fill over it as long as you key it up, and it comes off easy enough for metal work/welding. Once the welding is done, I use single pack (spray can) epoxy to cover it, tho you could mix 2k epoxy and spray or even brush on if its a small bit. Thats just what Ive done, I'm not an expert.
  28. T. Turtle
    T. Turtle
    Joining those who advised epoxy, that's I used to apply when I was doing bodywork for living. That was in the UK so skipping on it meant cleaning the metal all over within 3 days, lol. I don't suppose conditions are as bad as in the UK where you are but better safe than sorry.
  29. Epoxy. Never leave bare metal
    klleetrucking likes this.
  30. overspray
    overspray
    When I did my Model A coupe I blasted it, sanded the blast texture smooth with #180 DA, solvent wiped it and used mild self etch primer, and, after the recommended flash time followed with 2 good heavy coats of 2K urethane hi-build primer. I wasn't able to get to the bodywork right away so this was a great system to take care of any minimal rust in the sandblasted steel and protect the body until I was ready for body repair. When I was ready for body work, I ground/sanded the primer off the area to be replaced/repaired and welded in a patch or hammered and filled dents. I worked on it a section at a time and reprimed each section I repaired after I finished the area.
    Metal prep (acid wash) would have been another option instead of the self etching primer, but it's messy and much more time consuming. My sandblast job left the steel looking really clean, but I knew there was probably microscopic rust in the metal that you can't see. The self etch primer was a very good option for neutralizing and converting the small amount of rust to iron phosphate with my limited time to get the metal protected in my time frame. Following the etch primer with the 2K urethane is the recommended process and compatible primer for applying over the self etch, and gave me good (primer) film thickness for protection of the metal for long term storage.
    Epoxy primer does NOTHING to convert rust. Some epoxy primers are better than others in moisture resistance, cure time, film build, and ease of sanding, but they are not all the same. If you use an epoxy, make sure to do some research to see what will work best for your application. You still have to treat or remove the rust for the best results.
    Metal conditioner, phosphoric acid, will affect the hardner part of epoxies and cause them to not cure at all or possibly, only partially. Some epoxy primers have cautions or warnings about using them over rust converters, metal prep acids or self etch primers because of this, so make sure to neutralize acids before you apply epoxy primer(s) and check the tech sheets for specific information.
    After I sanded and cleaned the sandblasted steel, I used Transtar self etch primer: https://www.tat-co.com/TranstarAutobodyTechnologies/media/TATCo/Product ***ets/English Datasheets/transtar_tds_6111-F.pdf?ext=.pdf
    There are other comparable brands available.
    Followed by a compatible 2K hi build urethane primer: https://www.tat-co.com/TranstarAutobodyTechnologies/media/TATCo/Product ***ets/English Datasheets/transtar_tds_6921.pdf?ext=.pdf
    There are other brands of comparable products and I have used Kirker's 2K urethane hi build with very good results.
    anothercarguy likes this.
