Sandblasting inner brake drum?
Discussion in 'The Hokey Ass Message Board' started by 56 ford custom, Mar 27, 2013.
  1. 56 ford custom
    56 ford custom
    from Socal
    I had a brake drum sandblasted for my 1960 Ford F100 and the guy blasted inside my drum where the brake shoes rub to stop, Can I still use it or is this going to cause problems?
  2. stuart in mn
    stuart in mn
    I'd get it turned at the local brake shop.
  3. black 62
    black 62
    from arkansas
    good way to get it out of round...
  4. 56 ford custom
    56 ford custom
    from Socal
    Well that ruined my day
  5. upspirate
    upspirate
    I'd take it and have it mic'ed at a brake shop....they can turn it if not too far gone
  6. timwhit
    timwhit
    Having it turned should true it up, if it is out of round at all. The machinist can tell.
  7. upspirate
    upspirate
    PS,I won't tell you about my expensive mistake day that's not over yet!!!:(:eek::mad:
  8. Rusty O'Toole
    Rusty O'Toole
    You can use it and it won't cause problems. I have sandblasted brake drums before and used them. If it was not rutted and out of round before it won't be now. You could give it a rub with 120 sandpaper and blow it off with air if you like.
  9. 56 ford custom
    56 ford custom
    from Socal
    Hell.....why not? Haha
  10. 56 ford custom
    56 ford custom
    from Socal
    So it will eventually end up smoothing out?
  11. 42merc
    42merc
    Please tell me how sandblasting is going to make a brake drum out of round.
    If that were so, then blasting the outside of the drum would warp it. If it was straight to begin with, it will be straight after. as far as roughness on the braking surface, about ten stops later it will be as smooth as new.
  12. snopeks garage
    snopeks garage
    from macomb MI
    yes
  13. black 62
    black 62
    from arkansas
    no ---i was thinking that rust build up on one area could cause over application of blast media and i was ***uming industrial grade equipment---drums are not that hard to get out of round or else there would not be a brake lathe on every corner...
  14. snopeks garage
    snopeks garage
    from macomb MI
    if you can sand blast sheet metal and not bend it how will you get a drum out of round? if your brakes were fine before they are the same now.
  15. kippers 34
    kippers 34
    I blast them all the time before powdering. Odds of hurting them are slim to none. As said lightly hand sand or lightly turn and good to go.
  16. bobss396
    bobss396
    I agree, it will be fine. The shoe contact will knock down any surface roughness in a short time. Actually you're better off having them a bit too rough as opposed to too smooth.
    Bob
  17. CutawayAl
    CutawayAl
    from MI
    It's not an ideal finish, but if the drum is round and true, and the blasted finish isn't too rough, you can likely get by with using it as is.
  18. Mr48chev
    yep, it shouldn't be a problem if the surface is smooth on them, As Rusty said, you could scuff them with some sandpaper but I'm not even sure that is necessary.
    Sandblasting them will NOT get them out of round, that is total BS. If they are out of round after they are sandblasted they were out of round before they were sandblasted. They are cast iron not tin.
    I'd have them checked as a matter of course before I put them back on and have them turned if they need it.
  19. 56 ford custom
    56 ford custom
    from Socal
    They arent super smooth like before nor are they like 80 grit paper either.
  20. exactly! I blast them all the time!
    Thats a ****load of crazy comments posted, your not reshaping metal!
    I just wish if people had no knowledge of certain things, then dont post in those threads.
    This happens to be something I deal with all the time, the worst thing you are going to do to the drum, is help it... by removing built up glazing.
  21. upspirate
    upspirate
    As to your drum, I'd have then check them and do a light surfacing if they are in spec
    As to my day, I searched to find what brakes/calipers were used on my 32,and came up with 72 Chevelle.....I didn't notice til after I turned the cores in and painted the new ones an installed them that the hoses enter at a different angle than my old ones.
    72 Camaro have the angle I need to clear my dropped axle.
    So another set of calipers + core charges unless I use my new painted/modified as cores!!!!
  22. 56 ford custom
    56 ford custom
    from Socal
    Well that sums it all up. Thanks a bunch guys
  23. 56 ford custom
    56 ford custom
    from Socal
    Damn that's horrible
  24. upspirate
    upspirate
    Oh well, could be worse....I could have just threw it together and not noticed til I turned sharp and damaged the hoses and lost my brakes!!!
    $60 is really cheap stupid tax in the scheme of things!!
  25. After 24 posts no one has hit the real problem. The sand will penetrate slightly the surface and remain there. The result will eat cutting tools when the drums are turned. Be sure to get a fixed price and hope the shop hasn't encountered sand blasted drums before. It will be a learning experience for them. Don't worry about the sandblasting warping the drums.
    Charlie Stephens
  26. 33sporttruck
    33sporttruck
    Wipe the inside of the drum with lacquer thinner or brake clean then dry them and run them.
    I ran a brake lathe in the Old Mom & Pop Type Auto Parts Store. Once a drum is turned it looks like the minute grooves on an old vinyl record. It is not shiny, shiny !!!
    The brake shoes will wear in and be okay.
    If you think it is warped, it was warped before the Sandblast Job.......... Jeff
  27. chubbie
    chubbie
    interesting:rolleyes: you guys just give your untried negative opinions and posser theory on subjects you have no knowlege of??
    this will get you go'n! I sand blast my brake drums AND BAKE THEM IN AN OVEN TO 400 deg. and powder coat them!!! and then i drive on the same streets as your children LOL!!
  28. Joe H
    Joe H
    Interesting how how the sand can be penetrate the cast iron and dull a cutter when they were made in a sand casting and probably sandblasted or tumbled when new.
    Mount them backwards and spin them with the engine while sanding them slightly to smooth out the sand blasting finish. Flip them back around mount the tires and go!
    Joe
  29. HOTRODPRIMER
    HOTRODPRIMER
    Sandblasting certainly is not going to warp a cast iron brake drums surface,,it really isn't a big deal.
    They only negative I can think of is the brake shoes may wear slightly quicker due to both the surface of the drum and shoe having a rough texture.
    If they were mine I would have them turned just to get them smooth again. HRP
  30. cabriolethiboy
    cabriolethiboy
    I've been doing it for 30 years. No problems yet.
