Sandblasting
Discussion in 'The Hokey Ass Message Board' started by 1949P17BC, Jan 4, 2010.
  1. 1949P17BC
    1949P17BC
    from Ballwin MO
    Started on my next project a 1948 Dodge 1/2 PU. This is by far the most rust and rot. I have pulled all of the sheet metal, doors, fenders etc off. I plan on taking everything for sandblasting. I just knocked out the big chucks of rust and bdy putty and whatever else the previous chucklehead used for fill. I ***umed it would be easier after its blasted to see what and where needs to be cut out. Tips and Advice
  2. Wicked_a
    Wicked_a
    from NoDak
    depending on how bad it is (might be left with nothing to work with) blasting is a good way to see what u really got
  3. Make sure the blaster knows what they are doing!
    Easy to warp thin metal.;)
    Bill.
  4. 56don
    56don
    Try to remove all the built up grease, undercoat and ****.Sandblasting won't remove anything soft,it just embeds it with sand.Coat it with something quickly if you can't put it in a climate controlled area.Condensation will rust it back very quickly.
