SATA spray gun ID, questions
Discussion in 'The Hokey Ass Message Board' started by henry29, Oct 10, 2009.
  1. henry29
    henry29
    I just picked up this SATA gun and can't find any info on it.
    The only markings I can find on it are KL.
    Is this an HVLP gun?
    How can I find out the tip size?
    Can I still get parts for it?
  2. henry29
    henry29
    Hmmm... pics might help.
  3. inliner54
    inliner54
    well im pretty sure its an HVLP its an older model thats discountinued. some times it says the size of the tip on the inside of the air cap. Im pretty sure its a primer gun check on the sata website.
  4. hotrod40coupe
    hotrod40coupe
  5. henry29
    henry29
    I looked through the web site and couldn't find any thing, not even in the discontinued list.
  6. inliner54
    inliner54
    i looked on the discountinued list found a couple of KL models but i cant read german. so that wont do you any good and ill have to say that sata has a very poorly designed website.
  7. SlowandLow63
    SlowandLow63
    from Central NJ
    Definitely a primer gun. The tip size will be stamped on the needle and also the fluid cap, and most likely the air cap. Parts might be hard to come by as Sata pulled back on distributing. Its getting harder and harder to fond parts for even current models.
  8. plodge55aqua
    plodge55aqua
    from Alberta
    Pull the Cap.. check the edge of the tip.. it should say 2.0 , 1.5. 2.5 .. a 1.4 , 1.5 would be great for base and clear.. a 2.0 tip would be good for primer.. but a little heavy for clear..
  9. jakesbackyard
    jakesbackyard
    from ND
    1. Upholstery
    I don't know anything about your gun, but all SATA guns sold in the US come through DAN-AM co. located in Minnesota. They have a great tech person. Give them a call.
    I can't believe it's hard to find parts for current SATA guns. We have no trouble at all. Find a local dealer for SATA and they should be able to help you.
    Here's the link: http://www.sata-gmbh.com/usa/
  10. SlowandLow63
    SlowandLow63
    from Central NJ
    Thats the thing. Before you could order parts and guns on internet mailorder. Sata pulled all that back so now you can only go to local dealers.
  11. henry29
    henry29
    Well, I found 1.5 stamped on the cap.
  12. HELLMET
    HELLMET
    primer sealer gun. good old gun.
  13. bobkatrods
    bobkatrods
    from aledo tx
    kl is a pretty old primer gun, however they are good guns,parts are cost prohibitive, needle and tip assy go for about $120.00 if you can find them. if you are in it cheap it will make a great primer gun,
