satin or glossy black????
Discussion in 'The Hokey Ass Message Board' started by dsiddons, Aug 7, 2009.
  1. Thats why you go single stage urethane! You can blend it, rub it out, whatever if you do sustain damage. I have sprayed Nason (budget Dupont), PPG and PPG's Urotech, an industrial version. All were easy for a garage painter and hold up really well.
    Shiny is where its at.
  2. Royalshifter
    Royalshifter
    Moderator
    ???:confused:
  3. plym49
    plym49
    from Earth
    Additional thoughts: if you decide glossy, I would definitely suggest the following:
    1. NOT base coat-clear coat. Single stage.
    2. NOT perfect-lacquer-with-60-coats-lovingly-wet-sanded.
    IOW, something that looks like an original black paint job that was well cared for and then rubbed out. Slight patina, ever-so-slightly satiny. This is REALLY hard to describe in words but hopefully you understand what I am suggesting.
    The end result would look good, be repairable, and also not make the car look bad as minor stone chips and the like appear over time.
  4. Von Rigg Fink
    Von Rigg Fink
    from Garage
    go against the grain and do what you want..you know you want Satin
    glossy is over rated
  5. 5w32
    5w32
    looks good in satin!
  6. The car will look great either way... But my vote goes to "Glossy".
  7. wrenchrocket
    wrenchrocket
    Do what will let you enjoy it most.
