Technical saved a flathead from the scrapper. how'd i do? **UPDATE**
Discussion in 'Traditional Hot Rods' started by classicKustomCarSales, Dec 1, 2013.
  1. Hard to tell with my small phone screen, but is that block factory relieved below the valves?
    Edit.....looked again, probably just seeing the outline from the head gasket.
  2. roseville carl
    roseville carl
    Instead of oil use a 50 50 mix of atf and acetone down the cyls should help to break it loose
  3. Goldy
    Goldy
    Ya Did Good !!! The s**** yard didn't need your flattie. Give them a Honda with a fart can instead!!! just my 2 cents worth.
  4. BigAl1961
    BigAl1961
    Nice to see someone save a flattie that doesn't look like it was on the ***anic!!!!!
  5. Hotrodmyk
    Hotrodmyk
    x2!!!
  6. J'st Wandering
    J'st Wandering
    I would take it apart.
    It may be the valves that are keeping it from turning or the pistons. Take the cam gear off and see if it makes a difference. It is easier to pull the pistons if the crank will turn some. Get the block stripped down and than check for cracks. The inside of the motor looks better than I was expecting.
    Neal
  7. classicKustomCarSales
    from midwest
    thanks neal this is what im going to do tomorrow. I the bolt just keeps tightening , started to rip into the washer, so im just going to take it all aprt. im not even planning on running this motor I just wanted to check its condition and learn a thing or two about them while I was doing it. so I was gonna take it apart whether it turned over or not, to check for cracks and other damage.
    ill keep you guys updated.
  8. classicKustomCarSales
    from midwest
    thanks everybody for all the info too its been very helpful
  9. classicKustomCarSales
    from midwest
    i actually got it to break free and turn over, I still yanked the pistons out and everything looked real good. I did have to break on of the pistons to get it out because it was surface rusted solid. all the cylinder walls look like a honing is all they would need, I never even paid attention to the sticker on the side of the block that said "remanufactured" lol that's why everything looks so good this ol girl has been freshened up sometime in the past. the crank looks great too. so im confident I have a good motor to p*** along to a willing hot rodder. I never was planning to keep this I just didn't want to see it go to the crusher and also get a little flathead 101 in the process. thanks a lot guys for the help anybody know what its worth?
      301 KB
      459.8 KB
      473.5 KB
  10. HammerDown
    HammerDown
    Unless it is magnafluxed you can't be confident it's a good block. Until then it's worth $0.17 a pound...
  11. J'st Wandering
    J'st Wandering
    I m guessing that a bare block that looks crack free is worth more than $20. :)
    Neal
  12. TheMerc
    TheMerc
    Sweet buy! I've spent a lot more for much worse before I finally broke down and ordered one from Precision Engineering down in TX. I think I might have an old 4 speed ****** for a truck sitting somewhere if you need it!
  13. mtflat
    mtflat
    I agree - if you had to break up one piston because it was rusted tight, there's a chance that cylinder may have a crack in it.
    It's not worth much until the true condition can be determined. Flatheads are fun!!
  14. rottenleonard
    rottenleonard
    Doesn't cost much to have a block magnafluxed I'd have it done, and if it comes out with a clean bill of health you have some good trading stock.
  15. classicKustomCarSales
    from midwest
    well damn I think ill let the next one I see stay on the trailer and get s****ped
  16. roseville carl
    roseville carl
    Well thats really not a great answer, you did get more than 40 bucks worth of learning out of it already. And who knows maybe with a little mag work you will have a great block that someone can use. Hell If there no real bad cracks fill er with alum and go racing, then you can really spend some money ..............
  17. Rich Wright
    Rich Wright
    If I was you (and of course I'm not so this my not mean much...) I'd clean the **** of the block by hand....Lots of gentle heat on the grease and/crust, a s****per and wire brush. Scrub it till it looks like it's been hot tanked.
    You can see pretty much any damage that way and save the Magnaflux cost if you happen across any bad cracks.
    Pay extra attention to the webbing around the base of the cylinders..I hear this is potential bad spot. also, the entire deck as already recommended.
    If you don't see any cracks odds are greatly improved that you have a good block.
    No matter what, you have a good crank and rods, plus all the miscellaneous stuff like fuel pump stand, rebuildable water pumps, timing cover, pulleys, flywheel, etc, etc,....
    And just for fun....I'd measure the stroke on the crank. More than one guy has gotten lucky on replacement/remanufactured engines plucked out of old greasy cars/trucks.
  18. King Callie
    King Callie
    from Virginia
    40 bucks was a steal. Now savor the flavor because a nice build is going to cost a few bucks! Currently into a stroker build and I quit keeping track of the money spent.
  19. HammerDown
    HammerDown
    I'm not busting balls. The guy is obviously wanting to sell it, which is why he asked what it's worth. I stand by what I said, and any serious buyer is going to want PROOF it's good before paying a premium price - not "Well I don't know anything about it but I took it apart, busted a piston out and I think it's still good".
    To the OP - don't get your ******* in a bunch. It's good you saved it from the s****yard, and as the other fellas said you got more than $40 worth of knowledge and parts. If you are serious about selling it, have the magnaflux done and you have something you can factually represent. Until then it's just parts.
  20. classicKustomCarSales
    from midwest
    UPDATE.
    the crank is a mercury crank. I was bragging in an earlier post about how nice the crank looked and somebody told me to double check it because lots of times when they were rebuilt people would put the 255 merc crank in it and that's what it has!
    that makes it worth saving. I think ill put it on evilbay and see how I do
  21. classicKustomCarSales
    from midwest
    is the crank the only thing diffent from a 239 and 255?
  22. Super Streak
    Super Streak
    from Florida
    You should try selling it on the HAMB or Ford barn before you do e-pay. This way you may help one of the guys on this site out first.
  23. classicKustomCarSales
    from midwest
    that's a good idea super streak. thanks
  24. Hotrodmyk
    Hotrodmyk
    What he said...that's what HAMB is about.
  25. classicKustomCarSales
    from midwest
    false alarm. the crank looks brand new but it is not an upgraded merc crank like i thought. shes just a 239.....
  26. saltracer219
    saltracer219
    magnafluxing is not that hard or expensive. The biggest thing about magnafluxing is having a clean part. If you clean the blockyourself,remove all of the carbon and grease in the areas to be magged you should be able to find someone in a local automotive machine shop to mag it for well under $50.
