Saying Hello
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by coogan, Feb 21, 2007.
  1. coogan
    coogan
    Just new here, I must have been in a cave because I just found this site. I had actually started my own site but don't have many members yet.
    www.vintagerods.ca
    I have some questions for my next build so until I get some experts on my site I thought this might be a good spot to ask questions about my next build since there seems to be lots of guys in the know here. I just finished my 37 GMC, attaching a pic.
    My next build will be a 28/29 tudor slammed to about a 3 inch ride height. I scored a complete 40 ford frame today flat head and all. I'm going to use the front axle , brakes and split the wishbones. I want to do a suicide front end , but mount the spring to wishbones.
    My actual question was about rear end width. I did some searching and found quite a few threads but no real dimensions for a backing plate to backing plate measurement. I want the top of the rear wheels to be just below the bottom of the back window. I'm going to use 15 "wires with about a 3 inch backspace. So does anyone know offhand what backingplate to backingplate width I need and which axle to look for? I'm thinking mid 70's Ford pick-up ?
  2. pecker head
    pecker head
    COOL truck , welcome from TEXAS
  3. coogan
    coogan
    Thanks man. The ***le thing sounds like a drag. Up here all you need is the VIN number and to p*** an inspection once the car is done. Then you can get it registered.
  4. ZZ-IRON
    ZZ-IRON
    from Minnesota
    Hey Coogan * I Got To Say I Like The Truck ! Most Everone Stumble Into The Hamb.
    Unless Your Like Alice You Fall In The Hole And Find Wonderland. "I Did" * Rich
