Technical SBC 327 Cooling Issue
Discussion in 'Traditional Hot Rods' started by MichaelC73, Jul 3, 2023.
  1. 6sally6
    6sally6
    Use the lighter advance springs too !!
    6sally6
  2. Cooder2
    Cooder2
    from tejas
    I've built a number of hipo small blocks (furd not chev) and I don't consider 210 deg "overheating". You are at least 20 deg from "hot" in MY book...
    My current 351w with cam heads and goodies runs 195 all day
    MichaelC73 likes this.
  3. Blues4U
    Blues4U
    from So Cal
    Point of logic, if the water spends more time in the radiator shedding heat, then it also spends more time in the engine picking up heat, offsetting any benefit of spending any additional time in the radiator. Temperature differential is the biggest issue, the greater the delta T, the greater the rate of heat transfer. As the coolant temperature drops in the radiator, the rate of heat transfer also drops, reducing efficiency. Rather than have the coolant remain in the radiator, it is more efficient to have it return to the engine to remove more heat and bring it back to the radiator to release it, fast. The faster the better. This is why a high flow rate is more efficient than a lower flow rate.
    Cooder2, SS327 and MichaelC73 like this.
