Technical SBC 350 build- L82 2.02/1.60 vs vortec heads?
Discussion in 'The Hokey Ass Message Board' started by oldrelics, Jul 26, 2014.
  1. oldrelics
    oldrelics
    from Calgary
    So I'm planning: 350 4 bolt, forged crank, 10.0-1 KB claimers based on 76cc, mild cam. Which would be better HP gain, the 2.02/1.60 L82 heads or some vortecs?
  2. slammed
    slammed
  3. saltflats
    saltflats
    from Missouri
    Whats it going in?
    I would stay away from vortecs intake gaskets are***** and not traditional.
  4. the fel pro gaskets work just dandy.
    traditional, maybe not.
    do they perform, yes.
  5. jetnow1
    jetnow1
    from CT
    Vortec heads are 64 cc- quite a bit smaller than 76cc. Check what this will do to your compression on any of the online compression checkers.
  6. jetnow1
    jetnow1
    from CT
    Also vortec heads will require a different intake as they use a different intake bolt pattern, and require centerbolt
    valve covers if that matters to you. They will outflow any other stock factory head.
