Technical SBC 350 - How hot is too hot?
Discussion in 'The Hokey Ass Message Board' started by 53CHKustom, Nov 14, 2015.
  1. 53CHKustom
    53CHKustom
    Are you referring to the purple ice additive made by royal purple?
  2. Jose perez
    Jose perez
    That is correct...
    53CHKustom likes this.
  3. 53CHKustom
    53CHKustom
    Oh cool. Before I bought Watter Wetter I heard Purple Ice was also another alternative for reducing the surface tension of the fluid. Watter Wetter also claimed the 22 deg drop (when run with just water and no antifreeze).
  4. Jose perez
    Jose perez
    Also the purified water doesn't corrode the radiator or block like regular tap water... Also champ radiators out of Anaheim CA, makes 3-4 row aluminum radiators which will definitely help you stay cooler......depending on the distance of your fan. Thanks for starting this by the way... I'm actually learning some new trick to do on my 49 p18.
  5. Jose perez
    Jose perez
    I've ran just water and royal purple... If you read the directions it will tell what you can and CAN'T mix with it
  6. bobss396
    bobss396
    I will check the Royal Purple stuff, not to hijack the thread but this is my first car built with a lot of aluminum components (but I won't mention a sacrificial anode in case the OP gets wind of it...) on it.
    I have a Champion radiator (for a '65 Chevy) in my Ford, finished very nicely. And I have taken 'stats out of cars in the summer here in the NE when I had over heating issues and it works.
  7. Jose perez
    Jose perez
    Its purified water that I've ran inside not just tap water.... I went to a 7-11 and bought 4 gallons of water... To avoid the corrosion inside
    luckythirteenagogo likes this.
  8. st.rod
    st.rod
    Dear god this dumb *** thread is 8 pages long
  9. Jose perez
    Jose perez
    Your dumb *** should of stayed out.. can't believe you can't spell that either... Lol
  10. unkledaddy
    unkledaddy
    She's gonna blow!!
  11. hotroddon
    hotroddon
    I can't believe I sat here and read all 8 pages of this. But I'm waiting for a customer to pick up a car and I'm bored anyway so what the hell. I can't believe some of the "suggestions" either -
    Retard the timing from 14° to 8° to run cooler? Sorry pal, but retarding the timing will only make it run hotter. Change the cap to a higher pound will make it run cooler? Sorry Again, but that will only raise the boiling point, Not how hot it runs (or doesn't)
    Move the temp sender? WHY? yes they read hotter there, so What? the gauge is just an indicator of what's happening, the number isn't all that important. That's why the OE's put H and C, so folks won't fret over numbers.
    All these different % of water to antifreeze, in So Cal? What a waste of time. Somehow between "Some" antifreeze and "All Anti Freeze" will work just fine. Seriously, you are nowhere near the ragged edge of hot or cold in San Diego (Side note, did you know that when Hitler was going to rule the world, he had scientists figure out where the best year round climate was? And it was northern San Diego!)
    The truth is your car never was running hot! If it wasn't puking out coolant, and it wasn't detonating IT WAS FINE!
    By the way, I'm not sure that the cap you has is a coolant recovery type cap - yes they are different in that they let coolant out when you shut it down and the heat rises and the coolant expands, and then they let the coolant **** back in under vacuum when it cools back down. If the overflow bottle never seems to get the coolant dirty, I'd bet you have the wrong type of cap.
    Hope these guys show up soon, it's getting late and I want to go home!
    AHotRod, hipster, Model T1 and 2 others like this.
  12. wedjim
    wedjim
    from Kissimmee
    Keep it going! Quitters never win and winners never quit!
  13. Jalopy Joker
    Jalopy Joker
    see on craigslist that you have it For Sale
  14. Fedman
    Fedman
    For sale...... After all this........ :(
    I am sorry I even read along on this thread then...... :eek:
  15. fergusonic
    fergusonic
    from Kokomo, In
    number 9..... number 9...... number 9......
    Fedman likes this.
  16. Fedman
    Fedman
    Did you see what Ringo sold the special copy of the White Album for recently?
  17. fergusonic
    fergusonic
    from Kokomo, In
    Did he sell the White Album for enough to buy ....say.... a 1953 Chevy?
    wedjim likes this.
  18. 54fierro
    54fierro
    from san diego
    you guys are ridiculous, I'm going over to the square headlight in a round hole thread.
    Model T1 and wedjim like this.
  19. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    There's always the "what color should I paint my wheels" thread........
  20. captaintaytay
    captaintaytay
    Ya, I saw that car on CL, but it is a 1954 and a two door.
    His is a 1953 and a four door.
  21. Jalopy Joker
    Jalopy Joker
    - look in San Diego - 1953 Chopped Chevrolet
  22. wraymen
    wraymen
    Your not joking, Joker. Same pics and everything. I did not read the add, any mention of it running hot?:)
  23. squirrel
    he fixed that....waited for the weather to cool off :)
  24. captaintaytay
    captaintaytay
    Boy, I missed that, I only saw a 54' primered two door with red wheels.
  25. unkledaddy
    unkledaddy
    Looks decent in the CL pix...............but we've seen it underneath and up close
  26. wedjim
    wedjim
    from Kissimmee
    For sale? Well, while I'm here, what's the best oil to use? [emoji57]
    Model T1 likes this.
  27. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Pennzoil 20-50, and smoke camel non filters=at least two pack 's a day for optimal cooling/performance
    hipster and wedjim like this.
  28. Model T1
    Model T1
    Since you are in Florida the best oil is the kind you boil gator meat in. It'll also work in a 350 small block 53 Chevy if it's not too hot out.
    wedjim likes this.
  29. Budget36
    Budget36
    FFS, guy has his his car for awhile, making it right before he sells it, and then the wise ***es gotta jump in.
    Hope none of you have an issue with a vehicle you are selling, then come here for help.
  30. Model T1
    Model T1
    New 180 degree themostat
    New 14# radiator cap
    Make sure you have a good overflow system
    A good 5 to 7 blade metal fan with the correct pitch for an early 350
    A full radiator shroud available at most any junk yard. Measure your 53 Chevy radiator and get something close.
