Technical SBC 350, TH350 squeal
Discussion in 'The Hokey Ass Message Board' started by KPowers, May 19, 2024.
  1. KPowers
    KPowers
  2. twenty8
    twenty8
    Time for the large screw driver as a stethoscope trick.
    I know this sounds too simple, but I would be starting with checking the belt condition and tension.
    firstinsteele likes this.
  3. chicken
    chicken
    from Kansas
    Easy to unhook vac at the intake manifold to see if it changes. Hole in modulator hose or line? worth a try.
  4. primed34
    primed34
    Transmission pump hasn't picked up fluid yet.
  5. gimpyshotrods
    gimpyshotrods
    How much fluid did you put in it, and are you checking the level when it is running, and warmed up?
  6. KPowers
    KPowers
    Thanks for replies, ill check items called out - and report back
    Bob Lowry likes this.
  7. KPowers
    KPowers
    got it fully warmed up ran through gears, needed about 1.5 qts, also tweaked idle speed a little. noise eliminated when running still little whistle when shutting down. appreciate everyone's insight
    Algoma56 likes this.
