Hot Rods SBC 350 What am I missing?
Discussion in 'The Hokey Ass Message Board' started by 2935ford, Jan 27, 2017.
  1. 2935ford
    2935ford
    Seems I have an issue with the crank dampener pulley and the (short) water pump pulley.
    They do not match up? The dampener pulley is in towards the block about 1/4".
    Do I have the wrong pulley(s)/dampener or water pump?
  2. lothiandon1940
    lothiandon1940
    You know they make spacers for this problem.
    lothianwilly71, 19Eddy30 and Dino 64 like this.
  3. Nailhead Jason
    Nailhead Jason
    do you have any more pics? i can really see the lower pulley.
  4. Nailhead Jason
    Nailhead Jason
    if you use a 1/2" spacer you will need to get a longer crank bolt as well. The crank bolt will only be engage about 1/4 to 1/3 inch. you want more thread engagement if you want to be able to crank the motor over with out having to pull all the plugs out first.
    lothiandon1940 likes this.
  5. Jacob helms
    Jacob helms
    The pulley on the harmonic balancer should stick out pretty far
    Sent from my LGLS740 using The H.A.M.B. mobile app
  6. lothiandon1940
    lothiandon1940
  7. Mr48chev
    I'm thinking that may be the wrong pump pulley for that setup.
    When I was switching back and forth between short pumps and long pumps on the 350 in my 71 GMC I had to try several out of my stash before getting the pulleys to line up right.
  8. Nailhead Jason
    Nailhead Jason
    Don, Those are for the water pump pulley, the crank pulley ones look just like it only bigger basically. I have a bucket filled with Chevy crank and water pump pulleys just to match up good pairs. They are some that are a little different though the years and dont quite match up with other pulleys sometimes.
  9. Nailhead Jason
    Nailhead Jason
    i tend to agree you. Try to find a water pump pulley that will match up with your crank pulley before putting a spacer in behind the crank pulley.
  10. lothiandon1940
    lothiandon1940
    ...............You're right, Jason. In my haste I miss-read his post. Like you guys have suggested, I would attempt to find a different pulley that would line up better and not use any spacers at all if possible.
  11. Dan Hay
    Dan Hay
    You'd be surprised but there are many SBCwater pump pullies for different applications. I tried 3 before I got one that lined up with a single groove flat crank pulley.
    **EDIT. The conclusion to that story is I bought a chrome single groove pulley set off of ebay. I ***umed if they sell them together they should work!
  12. Montana1
    Montana1
    Might check the pulley mounting flange on the water pump shaft. I've seen them not pressed on far enough to line up correctly after they were rebuilt. Just a thought... o_O
    19Eddy30 likes this.
  13. 2935ford
    2935ford
    Thanks all.
    I prefer to "fix" the crank pulley as the alternator pulley and bracket was set up to match the water pump pulley.
    The water pump pulley is down properly.
    Montana1 and lothiandon1940 like this.
  14. RICH B
    RICH B
    I have had to press the hub further on the shaft on both of the last two pumps I installed.
    Sent from my Nexus 5X using The H.A.M.B. mobile app
    Lone Star Mopar and Montana1 like this.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I've never seen a short pump pulley with a straight snout like that. I agree with wrong pump pulley.
    INVISIBLEKID likes this.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Being off just a small bit magnify's further and further out of control when one try's to correct it else where. [​IMG]
  17. aaggie
    aaggie
    Alan Grove Components has a good write up on the pulleys on his website. He also sells the correct GM pulleys and his prices are reasonable. I found out a long time ago that buying new is better than spending a day wandering around a junk yard looking at greasy and worn out old pulleys. Just my opinion for what it's worth.
  18. manyolcars
    manyolcars
    Right! The short pump pulley is more V shaped, not straight sided
    INVISIBLEKID and Montana1 like this.
  19. 19Eddy30
    19Eddy30
    from VA
    Hot Rodding @ it Finest ,
    Not all way's a bolt on !!!:D
  20. el Scotto
    el Scotto
    from Tracy, CA
    What this dude says! ^^^^
  21. el Scotto
    el Scotto
    from Tracy, CA
    I ran into this problem a few years back, there were different hub depths on the short water pumps.
    It's easy to fix if you have a press.
  22. paul55
    paul55
    from michigan
    Looks like the wrong pulley for the short pump. You need the one that is more cone shaped, I believe.
    Atwater Mike likes this.
  23. Atwater Mike
    Atwater Mike
    Paul's right...the more conical shaped one is 1/4"+/- deeper, and greater diameter at pulley, clearing the casting nicely.
    A word to any of the guys wanting to move the flange rearward on their water pump:
    First remove the back cover, then support the shaft rear at the impeller. Otherwise, moving the shaft inward of the seal will cause INSTANT water pump leakage!
  24. 2935ford
    2935ford
    Ok
    Thanks for all the input.
    I had no pump, pulleys or balancer that came with this engine as it was a block that had been worked on tanked, mag'd then (.60 over) but never sold. So yes, it has been a found this one, got that some where else deal.
    I'll look into Alan Grove Components.
  25. tb33anda3rd
    tb33anda3rd
