SBC 6-71 fuel pump problem....
Discussion in 'The Hokey Ass Message Board' started by JohnnyCASHcadillac, Dec 10, 2012.
  1. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I am running a SBC 350 with a bds blower. I have gone through 2 Holley fuel pumps and now 1 carter. They are both mechanical pumps rated at 120gph. The tank is vented and I have a 8psi regulator at the carbs.
    Twice they have gone out on the freeway after only 20 miles. The pumps are only lasting 3 months max!!!
    What else could be my problem??
  2. landseaandair
    landseaandair
    from phoenix
    Have you dissected any to exactly see what failed?
  3. hd4unm
    hd4unm
    Electric motors can go if not enough juice under load. What gauge wire are on them. And the obvious, check you ground is adequate. Some pumps are made to push not pull. Where are they mounted?
  4. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I haven't gone through any.
    They are mechanical pumps
  5. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    What should I be looking for. Never done it....
  6. hd4unm
    hd4unm
    Mounted so direct on the block right? Hmm.
  7. hd4unm
    hd4unm
    So is the diaphragm failing and gas spews out the breather hole?
  8. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Yea mounted on the block.
    No I just get no fuel pressure at the carbs...
  9. landseaandair
    landseaandair
    from phoenix
    A failed valve, torn diaphragm, debris from the tank, etc. Did it leak, low pressure or just stop pumping? Are you sure the pumps really went bad or could there be some wierd issue back towards the tank (pulling air) that is causing starvation and losing prime after long distances under load?
  10. hd4unm
    hd4unm
    This smells funny and not like gas.
    Mechanical pumps are pretty simple; lever, diaphram, one-way valve.
    Thinking...
  11. hd4unm
    hd4unm
    Is there a hidden filter on the ch***is maybe?
    What kind of tank? Any baffels in it?
  12. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    It is a model T tank with 2 vents. The tank was 1/4 full so I don't think the gas was moving to get air. I can se the carb bowls and they are bone dry. And If I crank it over after it stalls they don't fill up.
    Baffles in the tank and it has a fuel filter right out of the tank
  13. hd4unm
    hd4unm
    Something is weird. Have you talked to Holley? I could be wrong here but have never run a regulator at the carb with a mechanical pump. The carbs should handle the line pressure. Float goes down need and seat opens. Is the regulator recommended for that pump?
  14. indyjps
    indyjps
    What pushrod are you using, have you changed it with any of the pumps?
  15. landseaandair
    landseaandair
    from phoenix
    Any hoses look collapsed on the inlet side?
  16. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Good question. Will call bds
    The mechanical pump was already on the block so I don't know. Carter said that is one thing to check and see if it is too long and over extending the pump.
    All hard lines...
  17. 1960CHEVY
    1960CHEVY
    Silly question.
    Is the bottom of the Tank sitting higher than the pump?
  18. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  19. hd4unm
    hd4unm
  20. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I don't have a Holley on there anymore. Went through 2 and went to carter. That is what is on there now. I have done the math and 120gph should be enough.
  21. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I can run around town for a good 30 minutes no problems. This last time going to a show I drove 30 miles there early in the morning and no probs. on the way home after 10 miles it failed.
  22. hd4unm
    hd4unm
    I agree in volume but you had what appears to be the same problem with booth brands. The old holley #s might expose some clues.
    This feels like supply or heat, maybe both. Hard to believe these pumps are failing.
  23. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I think it's the pump because now after sitting it still won't start or fill the carb bowls.
    Thoughts??
    You guys are really helping out!! Thanks :)
  24. hd4unm
    hd4unm
    Crack the line between the pump and regulator. Thighten and try again. See if you can here any air or witness pressure relief.
  25. hd4unm
    hd4unm
    Also check that carter number. Some pumps do need a reg, some do not.
  26. oj
    oj
    When a pump ****s out, is it just a replcement and then you drive off? No pressure with old pump, good pressure new pump and no other changes etc?
    When you pull the inlet fuel line, is fuel flowing freely?
    I'm curious about the 8psi, the only fuel pumps i am aware of that need regulator and can get above 8psi are the 160gph race type, none of the 120gph pumps get much over 7psi. I don't think it has anything to do with what is going on, it is just a conumdrum.
    I presume you have 3/8ths line to feed the carbs?
    Can you rig a gage where you can see it while driving, that might give you an idea of what is going on.
    Try cracking the fuel cap in case the vent is plugged.
  27. landseaandair
    landseaandair
    from phoenix
    Before the pump too.
  28. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Good vibrations said that I DO need a regulator but I will double check with carter.
    Yea. New pump= start and drive away.
    It is all 3/8 hard line...
    Could the regulator wreck the pump
  29. landseaandair
    landseaandair
    from phoenix
    Nope. Try cracking the line to the pump inlet, tighten it back up and crank it over a bit to see if it starts pumping again.
  30. hd4unm
    hd4unm
