Hot Rods Sbc alt bracket w/headers
Discussion in 'The Hokey Ass Message Board' started by scotty t, Dec 13, 2019.
  1. Anyone know of a better version of this bracket? I’ve got a project in the planning stages that will use this type of bracket. I’m hoping to find something better. Pics of homemade parts would be great also.
  2. Lloyd's paint & glass
    Do you have room to put it on the bottom? Screenshot_20191213-220538_Gallery.jpg
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What exactly is it you dislike? It's looks or it's ability to stay put?
  4. squirrel
    If you have bolt holes in the ends of the heads, then you can use the 1969-72ish truck bracket. If no holes, then you have to do something else...see what Alan Grove is making these days, perhaps?
    That bracket you have, does really ****...
  5. The project is the ole 57 vette with old heads with no holes, I don’t think the lower mount would work. I’m just looking for something more sturdy and maybe better looking. That is the only bracket I’ve seen for that application I was just hoping for something “nicer”
  6. Check the Welder Series catalog- pretty sure they have an alternator bracket for short or long pump with early heads
  7. Thanks I will
  8. 54BOMB
    54BOMB
    7EA24F5F-9AA9-409D-BA53-63BA4E4E3A41.jpeg 00214491-37A5-41B4-8232-63DB93E17343.jpeg I made this flat bracket and attached the regular mount on top of it due to the size of the tubes , works pretty good , not very pretty though
    mgtstumpy, scotty t, Blues4U and 3 others like this.
  9. DDDenny
    Scotty
    I just couldn't find anything I liked so I came up with my own lashup.
    This is on my roadster.
    mgtstumpy, scotty t and catdad49 like this.
  10. sunbeam
    sunbeam
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Could not find a photo of what I've seen custom built a few times so I'll just describe what it was. Steel (Z shape, 2 vertical 1 horizontal) cut (lower vertical of Z shape) to exact shape of header flange then welded to header flange so it's not removable just like a stock exhaust manifold. Then the only part that is bolted on is...
    scotty t likes this.
  12. squirrel
  13. aaggie
    aaggie
    I have used Alan Grove stuff on several builds and it is good stuff. Quality made and fits perfect. reasonable prices.
  14. 4wd1936
    4wd1936
    from NY
    I have used that or a similar bracket by simply adding a support from the bracket to the upper water pump bolt, a stud makes it removable without disturbing the water pump bolt itself. Low budget but it works.
    scotty t and wraymen like this.
  15. wraymen
    wraymen
    The Alan Grove bracket I used has a bracket that goes to the upper bolt on the water pump. It also connects to the two outward intake bolts. The stud is a good idea. I have had to remove it a few times and no leaks at the pump but I like the idea of a stud and separate nut.
    scotty t and lothiandon1940 like this.
  16. Pass The Torch
    Pass The Torch
    Mounts to front intake bolt, top water pump bolt. P*** side.
  17. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    That's a total brand bracket I think.....had one on my A coupe
  18. That's a 70's Corvette smog pump bracket if I remember correctly.
    squirrel likes this.
  19. Pass The Torch
    Pass The Torch
    You would have to come up with a pivot hold down; this is how it’s set up on my ‘37.
  20. I guess i should have been more clear. I want to leave the alt. in the same location i just want a better bracket . The Alan Grove bracket may be the ticket. Thanks.
    Black_Sheep likes this.
  21. Just Gary
    Just Gary
    I used the same bracket as yours, @scotty t , but drilled a row of "lightening holes" in it and in the top hockey-stick-shaped bracket, then used a dremmel & files to amooth them out, and finally had them and a few other parts power-coated.
    Hope this helps.:)
    lothiandon1940 likes this.
  22. squirrel
    The adjustment on that setup doesn't do much, eh? The belt length hardly changes as you move the alternator through it's arc, since the pivot is between the alternator pulley, and the other two pulleys.
  23. Pass The Torch
    Pass The Torch
    Not my design, but no! Tall valve covers are out of the question as well. Not ideal, but it works.
  24. vtx1800
    vtx1800
    I plagiarized Alan Groves design and made my own, probably not the same quality but good enough for the guy using it. The pictures show it installed , then after I decided to powder coat it along with some other pieces I made, I am a CASO (cheap ***ed Studebaker owner:) IMG_2513.JPG IMG_2551.JPG
    Just Gary likes this.
  25. blue 49
    blue 49
    from Iowa
    A couple of pics of mine made for a Suzuki Samarai alternater. I added more holes front and back later. 008.JPG 006 (2).JPG
  26. Thanks for the replies but I’m just looking for a higher quality version of the bracket in the first post.
  27. squirrel
    The bracket in the first post is a lousy design. The other brackets we've shown you are higher quality setups, to replace it.
