Technical SBC Bellhousing Alignment? Or?
Discussion in 'The Hokey Ass Message Board' started by midnightrider78, May 11, 2023.
  1. Budget36
    Budget36
    I’m glad you mentioned “T56”. Got me to thinking “Hmnn, I better look into this”.
    Edit: I had the impression they installed like an automatic for some reason.
  2. 1971BB427
    1971BB427
    from Oregon
    I've never had an issue with the surfaces that bolt to the block, and the trans surface being true. It's the center hole where they're almost always off and need to shift using offset pins. I've had one that was perfect, and it was an ancient two piece stamped steel Lakewood I bought when I put the 468 BBC in my '63 Falcon g***er. I honestly was shocked when I bolted it to the flywheel and began turning the engine over and it was within .002" of true center!
  3. We drilled through the side of the block into the dial pin
    Budget36 likes this.
  4. Budget36
    Budget36
    I see, to stake in (so to speak) so the dowels won’t move. I ***umed a tighter fit for them and the position wouldn’t change.
    anthony myrick likes this.
  5. 42merc
    42merc
    I also drill & tap the block for a 1/4" setscrew.
    Johnny Gee and Budget36 like this.
