Hot Rods Sbc c1962 water pump?
Discussion in 'The Hokey Ass Message Board' started by Torana68, May 12, 2022.
  1. Torana68
    Torana68
    from Australia
    ok I have a “one size fits all” new pump. As far as I can remember the circled mounts are for later things? what for and Ok to cut off and re polish ? (No I don’t have an old one to look at)
  2. squirrel
    that's a "long" water pump, from 1969-later. It's not a 1962 style pump, which is shorter. Make sure it'll fit in your vehicle, and that you understand how the accessory brackets are different, and the pulleys are different, for the two styles. The original brackets for the alternator and power steering pump use those holes to mount.
    olscrounger and lothiandon1940 like this.
  3. abonecollector
    abonecollector
    that long pump will be way out of alignment for your lower crank pulley. Probably, even more so because of the thickness of that fan pulley on the water pump.
  4. Torana68
    Torana68
    from Australia
    ******, your right it is a long pump, back to the drawing board :( thanks all !
    lothiandon1940 likes this.
  5. lothiandon1940
    lothiandon1940
