Technical SBC CARB POLL
Discussion in 'Traditional Hot Rods' started by Jenkins Competition, Jan 11, 2021.
What Is/Are Your SBC Carb(s) ?
Poll closed Jan 18, 2021.
  1. Single Holley/QF 4bbl VS 670
    10.1%
  2. Single Holley/QF 4bbl DP 650
    6.5%
  3. Multiple 2 bbls any brand
    13.1%
  4. Multiple Holley/QF DP
    0.6%
  5. Multiple Holley/QF VA
    1.2%
  6. Edelbrock/Carter
    39.3%
  7. Rochester
    18.5%
  8. Single Holley/QF DP 750
    1.8%
  9. Single Holley/QF VS 770
    2.4%
  10. Holley Dominator or 3 Bbl
    1.8%
  11. 2 x 4’s, not Holleys
    4.8%
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Here's a look over my shoulder. Holley 650 Double Pump
    triumph 1, mad mikey and Deuces like this.
  2. DDDenny
    Only one vote per entry huh!
    Holley #3245, 585 cfm, easy decision, correct OEM carb for my 327/350 hp Nova engine.
  3. BigDogSS
    BigDogSS
    from SoCal
    You should probably separate out Rochester into "4GC" and "Quadrajet".
    Elcohaulic likes this.
  4. mad mikey
    mad mikey
    950 cfm Quick Fuel double pumper, custom built blower carb. On my Gary Dyer built 471 blower. WIN_20170423_12_34_39_Pro.jpg
    Dino 64, Deuces and Blues4U like this.
  5. L-79 ?
    Deuces likes this.
  6. indyjps
    indyjps
    Carb body, you can buy the whole carb with that set up.
    Carb spacers are more of a tuning tool for me, moves your power band around a little. A Friend used to swear by them and swap spacers to control his launch if he was blowing off the tires - I though it was BS but he had a system.
    Secondary linkage, looks nice, if someone takes the time to tune with it.
    mad mikey and Tickety Boo like this.
  7. hotrodjack33
    hotrodjack33
    Edelbrock 1406 on everything but 6 cyl's
    GlassThamesDoug, SlamIam and jim snow like this.
  8. 19Eddy30
    19Eddy30
    from VA
    Choose a brand & model close to CFMs
    Pluse 30-50 Cfm bigger ,
    ( Carb or Carbs) 1 Barrel 2b,3b 4b.
    Then Test , Tune. Keep notes . Adjust to Engine requirements & performance you are looking for,
    Sometimes the carb You pick is not the one you need , Then you need a smaller or bigger carb , VAC or DP .
    Carb Turning is more then mixture screws ,jets, power valve , metering rod.
    Those are basic
    I Prefer a carburetor's that is completely adjustable in all aspects.
    Over the Years I have ac***ulated over 30 carbs multiple mechanic injections
    For daily driven to Full out race
  9. Tickety Boo
    Tickety Boo
    from Wisconsin
    Changed two Holley vacuum secondary 750s and one 750 double pumper using the Proform centers, all ran quicker 1/4 mile with tuning. Also changed a Holley 850 to a 1050 using the aluminum Quick Fuel center, that one came out noticeably lighter but the old 850 ran a better 1/4 mile m.p.h.
  10. Ebbsspeed
    Ebbsspeed
    @Jenkins Compe***ion I couldn't vote because I run a Fish carburetor. I guess you're not familiar with some of the older performance carbs, eh?
    Montana1 likes this.
  11. Late at night, when the coyotes are up in my back yard, trying to catch cats, i watch the television. And one of my programs is the engine masters on motortrend. They did a test with an edelbrock, street demon, and the summit brand carb that Holley builds. That summit carb was by far the most affordable, and it blew the other 2 out of the water. Like 25hp iirc?
  12. DDDenny
    Holley 750 by Braswell for the 427 small block in my roadster.
    mad mikey, Tickety Boo and Deuces like this.
  13. Weedburner
    Weedburner
    from Wa State
    Single 625 Weber on a 900 or so 355 sbc...
    Crossbar plate with no nitrous "jets", the ported solenoids serve as the jets...
    All pretty much hidden under the air cleaner base...
    Grant
  14. Deuces
    Deuces
    Nice!....:cool::D:)
    mad mikey likes this.
  15. southcross2631
    southcross2631
    Depends on your intended use of that small block.
    I have ran anything from a small Holley or Edelbrock on a stock small block to (2) 660 double pumpers on a tunnel ram on a drag race only 358 inch . By the way you could drive that on the street with a .630 lift solid roller .
    I have won many features with a Qjet on a dirt car. Which when set up by someone who knows how makes the best street carb for a small block.
    The last small block Chevy I built for a customer used a Summit brand carb and ran perfect.
    I use an AED 820 cfm Holley double pumper on my 334 inch Ford motor and it is a bad *** carb.
    Just Gary, mad mikey, Deuces and 2 others like this.
  16. paul nervo
    paul nervo
    Rochester 2 bbl. 2 jet . 3x2
    Deuces likes this.
  17. Baumi
    Baumi
    How ´bout a leaky Holley 94, it´s got all those bells and whistles.... and a s(t)ink!
  18. 1971BB427
    1971BB427
    from Oregon
    The plenum divider has a small cut down area as it came to me. It looked original, as cast, so I didn't do any further cutting. The spacer I have is a 4 hole, not open plenum style. It serves to raise rpm peak HP, but also gets the carb bowls up away from intake manifold heat. Both good for my car.
    Deuces and mad mikey like this.
  19. Agree 100% “get carb away from heat”
    HVH 4 Hole
    Deuces likes this.
  20. BBC2981F-DE52-40F4-A862-11058696D7E2.jpeg 1930D956-3188-46D8-862D-8513E46141CE.jpeg
    Changed my LSAB’s this morning !
    Looks like this guy
    is “tinkering” too.
    Deuces likes this.
  21. bill gruendeman
    bill gruendeman
    Multiple carbs for looks hands down. A Q jet if you are cheap like me (and have one already), but with that said I have a Holley street avenger and love it a lot.
  22. 55blacktie
    55blacktie
    For a mild, street-driven SBC? 600 cfm Holley/w vacuum secondaries.
    Deuces likes this.
  23. Larry Goebel
    Larry Goebel
    from michigan
    my choices are two Holley 450's on my 327 sbc and two Holley 94's on my modified 235 blue flame
    Deuces likes this.
  24. nunattax
    nunattax
    625 cfm vs barry grant 4 barrell.runs fine gotta put the choke back in.like to try the newish 425 square one (demon)
  25. mad mikey
    mad mikey
    3x2 set up I had on a 355 SBC years ago. Rochester 2G's on a Offy intake. WIN_20160212_114535.JPG
    Deuces, Tickety Boo and Budget36 like this.
  26. jimmy six
    jimmy six
    Guys that use them swear by them.... not at them.....
  27. Montana1
    Montana1
    <<< 1407 Eddy 750 :cool:
  28. swade41
    swade41
    from Buffalo,NY
    All 4 of my old cars have 2x4 setups, some have Carters, some have double pumpers and some have 4160 style Holley's, all 1-1 linkage.
    The small blocks
    600 Carters
    4160 Style 450 cfm Holley's
    Same kind of 450 cfm carbs on this one too
    31hotrodguy, Deuces, Baumi and 3 others like this.
  29. 57JoeFoMoPar
    57JoeFoMoPar
    My Holley 600 cfm single inlet, vacuum secondary carbs have been amazing. I've had Edelbrocks and they're fine too, but I always seem to like the performance of the Holley better. I currently have those Holleys on my 383 Mopar, and my 324 Olds, both of which run a tad rich but very well. My 61 Olds is getting a dual quad SBC with 2 Edelbrock AVS2 series carbs, 500 cfm jetted for dual quads.
    triumph 1, Deuces and mad mikey like this.
  30. Swade41,
    You run that TR on the street ?
    What brand is it ?
    Nice !
    Deuces likes this.
