Ok, I have a SCB and i am tryin to figure out what the hell the heads are. I am use to seeing the symbold on the side of the heads. The ones I have seen most are the double hump symbols. But I havent seen the symbol that are on my heads before. I do not have a picture of it, or i would post it. But i can describe it as best i can. Basicaly it looks like a M but it doesnt come down to a point in the middle, it dips.
<font color="green">GO HERE And look up the numbers on the heads, they are inside the valve cover, between the valves. It will tell you what you want to know. RASHY</font>
Tha casting marks are one thing; casting numbers are the key. Check yours against this chart: http://www.mortec.com/castnum.htm It'll tell ya plenty about what you've got. Scotch~!
Check out Mortec , they have casting numbers for most sbc heads. Should give you the info you need. WWS
