Technical SBC chevy valve covers
Discussion in 'Traditional Hot Rods' started by MrNick, Dec 14, 2019.
  1. MrNick
    MrNick
    from Hemet, Ca
    I have a set of stock SBC valve covers that I plan to install. I noticed that one side is stright up and down and the other side is slanted. Why? Does it make any difference which way they go?
  2. tiger1930
    tiger1930
    Are you talking about the bolt pattern? I think early Corvette heads had a staggered pattern. Could they be a miss matched set?
    Sent from my SM-G950U using The H.A.M.B. mobile app
  3. And all the 327's was Corvette engines...
    He has a mismatched set
    One early and one later valve cover.
    Deuces and Chucky like this.
  4. redo32
    redo32
    Lots of different stock and after market covers over the years. Show us a picture so we can see what you have.
  5. 56sedandelivery
    56sedandelivery
    He's referring to the "intake manifold side" of the valve cover, as compared to the "exhaust manifold side" of the valve cover. Many times, if they get "flipped" around, the rocker arms will rub on the inside. Not all covers are that way.
    I am Butch/56sedandelivery.
  6. Lmao!!! That made me pee
  7. MrNick
    MrNick
    from Hemet, Ca
    That's it Butch. Which is the intake side? Stright or sloped?
  8. egads
    egads
    Straight side goes to the intake.
  9. MrNick
    MrNick
    from Hemet, Ca
  10. 57tailgater
    57tailgater
    from Georgia
    Learn something old every day!!
    The Shift Wizard and Hdonlybob like this.
  11. Muckler
    Muckler
    from NH USA
    I put a set of Holley valve covers on my pick up when I changed the heads. The original centerbolt valve covers (which I hate) would not work on the 1970 heads I put on. But the old cast Holley covers I had kicking around for years would, so I used them. A quick spray of Chevy orange and they were perfect for my beater pick up.
    I put one on upside down so I would have both the oil fill and the PCV up front where they are easy to reach on a pick up.
    jimmy six likes this.
  12. 54vicky
    54vicky
    you did not mention the intake
  13. blowby
    blowby
    from Nicasio Ca
    Do they fit your heads? :eek:
  14. 1934coupe
    1934coupe
    I just use covers that have writing on them, makes it easy for a guy like me.
    Pat
  15. DDDenny
    "This side up"
    1934coupe likes this.
  16. 62rebel
    62rebel
    "Motor" ..... I've been wanting to make a set that just say "Motor" on them... and wait for the inevitable "but it's not a motor, it's an engine" comments
    egads and Lloyd's paint & glass like this.
  17. dan c
    dan c
    early chevy had offset bolt holes in valve covers, i think '59 was the change. a lot of gaskets back in the day had four holes for the top bolts.
