SBC coolant bypass hose or not?
Discussion in 'The Hokey Ass Message Board' started by oldrelics, Aug 2, 2011.
  1. oldrelics
    oldrelics
    from Calgary
  2. Ratrod37
    Ratrod37
    Yes Plug away.I have two cars without heat or a byp*** and they work fine.I have had several other cars the same way and they all worked fine.I am sure there will be a few know it alls that will say you can't but don't believe them.
  3. gtkane
    gtkane
    I agree with RR37, plug away!
  4. dontlifttoshift
    dontlifttoshift
    Yes, I believe the only exception to that is later engines originally installed with vortec (L31) heads as those blocks did not have the internal byp***....I think.
  5. dirty old man
    dirty old man
    There's a byp*** built into the pump. Can't recall which side of the pump and I'm not @ shop to look @ a pump, but there's an extra hole below the main intput hole on the head. One side of the pump has a corresponding hole and this lets water within the block circulate when thermostat is closed.
    Only time I know of needing a byp*** hose is when you use a Zip's water pump riser as they have no byp*** provision.
    As stated previously, I never ran a byp*** hose on a race car with no heater!
    Dave
  6. P***. side. That's why the gaskets have the extra hole at the bottom.
  7. There wasn't any controversy, I said you needed one and some other fellas who don't think so said you don't.
    I have had them overheat without one put one on and it quit overheating. No logical reason why, I don't really care why, if it works it works. If I am running sans a heater I just put a jumper hose on and then I don't worry about it, my stuff doesn't overheat.
  8. oldrelics
    oldrelics
    from Calgary
    One thing I did find out if you don't have the byp*** hose or a heater you need an air bleed hole in the thermo stat.
