sbc cooling ?
Discussion in 'The Hokey Ass Message Board' started by pkj, May 1, 2009.
  1. pkj
    pkj
    hi, i have a couple of cooling system questions that i cant find out about when i search. first i have a cross flow radiator that sits a little lower then the engine, so i have put one of those blocks with a radiator cap in place of a thermostat housing. it comes with a 21-25 pound Stant cap. what pound cap should i use on it, and what cap should i use on the radiator? open system with a puke tank. second question; do i need a hose between the water pump and intake manifold or not? not running a heater. this is a 408 sbc, 11:1 CR engine. its running at 185 degrees, but havent had it out yet. thanks, pkj
  2. squirrel
    You probably want to leave the high pressure cap on the block, and use a normal 13 or 16 psi cap on the radiator, where the puke tank connects, so it should blow out that one first. No need for a hose on it, there's a byp*** p***age where the water pump connects to the block, that extra little hole at the bottom.
  3. Screamin' Metal
    Screamin' Metal
    from Oklahoma
    Do as Squirrel said....he's Da Man!!!!!!
  4. pkj
    pkj
    thanks much. i was going to try a 7 pond cap. glad i asked.
  5. Dirty2
    Dirty2
    I agree !
