Technical SBC decoding help
Discussion in 'The Hokey Ass Message Board' started by vintage44, May 24, 2017.
  1. vintage44
    vintage44
    from NY
    Guys, thanks to several posts here I've been able to find out a lot about a 350 I have. One thing I can't discover (and maybe it's not even worth anything) is the meaning of some casting symbols on the back of the block. One shows three letters - a 'T' a 'D' and an 'N' at a clock-type position of 12, 4 and 8 respectively with a pointer at the 'D'. Secondly there is a group of raised dots in a circle (10 dots) including a double dot at about the 3 o'clock position and a pointer at the dot in approximately the 4 o'clock spot. Ideas?
  2. FritzJr
    FritzJr
    Those symbols are for use by the foundry. Supposedly indicate the shift when the casting was made and/or the number of times a mold had been used.
  3. vintage44
    vintage44
    from NY
    Thanks, FritzJr.
  4. MAD 034
    MAD 034
    from Washington
    Sounds like a prototype Corvette casting. Could be worth $$$.
  5. all SBC s are from vettes
    afaulk likes this.
  6. gimpyshotrods
    gimpyshotrods
    Yup, 25 out of every 10 SBC's made and are in hotrods today came directly from Corvettes.
    39cdan, anthony myrick and mgtstumpy like this.
  7. a friend of mine pulled a sbc from a 60s vette
    decoded as a 70s truck smog era engine
    he was sad and gave me the engine
    I love getting stuff from folks that care about numbers
    39cdan likes this.
  8. Gman0046
    Gman0046
    To make sure your not being ripped off, make sure the SBC engine in question has Corvette valve covers. That will insure your getting an actual Corvette engine.
  9. sunbeam
    sunbeam
    Beware of factory original 2 barrel Corvette motors.
    afaulk and 39cdan like this.
  10. DDDenny
    Sounds like that "fuzzy math" to me!
    39cdan and lbcd like this.
  11. gimpyshotrods
    gimpyshotrods
    Ya think?!
  12. 39cdan
    39cdan
    This web site is the best one to break down GM codes. Since GM sand cast their blocks
    I don't believe there is any of the mold used more than once other than the sand box.
    http://www.mortec.com
    afaulk likes this.
  13. blue 49
    blue 49
    from Iowa
    Molds are used only once, but the pattern that the molds are pulled from are used thousands of times. At the start of the shift, someone changes the pointer and date codes on the pattern so that castings can be tracked in case something is wrong.
    Gary
    39cdan likes this.
