Technical SBC Distributor Stuck in Block
Discussion in 'The Hokey Ass Message Board' started by lake_harley, Jun 17, 2025.
  1. swade41
    swade41
    from Buffalo,NY
    I wonder if pouring boiling hot water down the distributor hole would shock it loose.
    This Jennings guy has some great videos of getting stuck engines running again, he uses a mix of acetone and trans fluid in the cylinders.
    49ratfink and tb33anda3rd like this.
  2. flynbrian48
    flynbrian48
    The distributor was seized in the 472 Caddy I built for my '36. I fretted over it for a couple days, then used some penetrating oil, a screwdriver and chisel driven under the distributor base on opposite sides and it popped right out. Didn't hurt anything. SBC distributors are cheap, wail away at it...
    427 sleeper likes this.
  3. PB blaster and a heat gun
  4. tb33anda3rd
    tb33anda3rd
    removing the heads without taking the manifold off reminded me of my buddies father who was a mechanic at a chevy dealership , he would remove just one head to do a head gasket without taking the intake off. he said he was a master at doing it, with no problems or come backs. all about beating the clock.
  5. Keep pouring/spraying some sort of penetrant you can in to the gaps in the distributor area. Pipe wrench on the distributor body, and keep trying to move it back and forth. Had one like that years ago, got it loose, in the car.
  6. partsdawg
    partsdawg
    from Minnesota
    Your friend must be extremely frugal.
    badshifter, Moriarity and Budget36 like this.
  7. lake_harley
    lake_harley
    Frugal is traditional, isn't it?
    When you have several engines that have been stored inside for several years why would you just take them to the steel s****per? I admire him for trying. You have to dis***emble them to see what's inside.
    Lynn
  8. squirrel
    I've wasted countless hours taking apart junk engines. It's fun, and you learn a lot. But you still have to buy another engine, at the end of the day.
  9. lake_harley
    lake_harley
    OK.....the "junk" talk seems unproductive and unnecessary.
    For the record the 1st engine was a .120" over, about 10.5:1 283 (301) that has been in the nice 40 Ford coupe since it was hot rodded probably back in the 60's. My friend bought the car from the previous owner's widow after the owner (a friend) p***ed. The car had sat for years. Upon dis***embly antifreeze was found in several cylinders and had taken it's toll through pitting.
    Engine number 2 (a 283) had been in dry storage for years but with a bit of examination it turned out to have badly pitted cylinders.
    Now, engine number 3 is a 350, stored in the dry for several years. It was complete carb through pan, and water pump through transmission tailshaft. Who would have guessed the distributor would be stuck in the block? It's still standard bore with only minor surface rust on the cylinders. To me, it's not junk if the distributor can be removed, since it still appears to be a rebuilder core after a .030" cleanup overbore.
    Lynn
    Truckdoctor Andy and 2OLD2FAST like this.
  10. squirrel
    Without pictures, we can make all kinds of wild guesses as to the condition of the engine.
    Moriarity and patsurf like this.
  11. lake_harley
    lake_harley
    I do appreciate the good suggestions offered on getting the distributor out. When we do get it out we can continue teardown to evaluate what we have.
    Thanks.
    Lynn
    2OLD2FAST, Toms Dogs and squirrel like this.
  12. Corn Fed
    Corn Fed
    The distributor in my running '65 283 was so stuck I had to use a pipe wrench to slowly break it free and then work it out. It took lotsa oil and back and forth to get it out. The wrench really chewed up the housing and it was a cast steel. I don't know if an aluminum one would have held up to the abuse.
    tractorguy and Algoma56 like this.
  13. RodStRace
    RodStRace
    I'd guess this is the first of a few hurdles. Lifters, cam, you already mentioned pistons.
    Guess it's too late to slap the pan and front cover on and soak it to the top with diesel/acetone/ATF.
    ****s for you and your friend. Best of Luck!
  14. warhorseracing
    warhorseracing
    from cameron wv
    BFH. Now that is traditional.;)
    squirrel likes this.
  15. Andy
    Andy
    The intake should have clearance under it from the gasket. The distributor should be able to move down. BFH could move it?
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Bringing it’s a 350 then it has to be an aluminum distributor. Pour/spray Coke or vinegar on it.
    deathrowdave likes this.
  17. I've had to use an air hammer on the side of the block for vibration while prying the distributor up to get it to come out. What a pain in the *** that ordeal was, and that block narrowly escaped the s**** pile over that BS.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    wrap a chain or cable around it, hook it to your cherry picker and lift it a few inches off the ground and spray your penetrating oil of choice around it and wait for a clunk....
    warbird1 and firstinsteele like this.
  19. 1971BB427
    1971BB427
    from Oregon
    I'd wrap a chain around the distributor and then hook it to a cherry picker. Raise the arm up until there's plenty of weight on the cherry picker, and then use a hammer to give some sharp raps to the distributor to break it loose. With the tension on the distributor as you smack it there's a good chance it will shock it loose.
  20. lake_harley
    lake_harley
    A little soak, and a bit more tapping and the distributor is out. :D Block is stripped and looking like a good rebuild candidate.
    Lynn
  21. 427 sleeper
    427 sleeper
    My dad was a Chevy mechanic too... did the same thing MANY times because warranty work never paid worth a ****! Anything to cut the book... ;)
  22. X-cpe
    X-cpe
    Hardest part was s****ing off the intake gasket.
    tb33anda3rd and Tickety Boo like this.
  23. 427 sleeper
    427 sleeper
    3M weatherstrip adhesive was his friend... if the gasket wasn't too ****ed up. ;)
    It was more of a pain in the *** to keep the antifreeze from the intake manifold from dripping onto the head gasket cement than anything else. LOL
    tb33anda3rd likes this.
  24. gimpyshotrods
    gimpyshotrods
    At least it is not a Ford.
    I once lifted an entre Cougar with a 351C off of the ground, using a forklift, by the distributor.
    I left it suspended for a few days. I still had to drill and chisel out the housing.
  25. 427 sleeper
    427 sleeper
    Damn Ford's... :rolleyes:
    SS327 and Tickety Boo like this.
  26. RodStRace
    RodStRace
    @lake_harley glad to hear! Hope the rest is simpler.
    Are you thinking of reusing the old cam and lifters? Does it turn now?
    Considering current stuff, it might be a cheap fairly reliable way to go rather than new questionable parts.
  27. 1biggun
    1biggun
    Considering a aluminum SBC distributor is worth about $10 unless it's special I'd not waste a lot of time trying to save it if you value your time.
    Beat it out from the bottom , heat , cold what ever it takes .
  28. patsurf
    patsurf
    too late
  29. deathrowdave
    deathrowdave
    from NKy
    I have had the dist ., very stuck also . I was lucky enough to spray it down with penetrating oil , tap it back and forth , spray it again and start the process all over again . It took a few hours , of working it back and forth , and it came free . Oiling it and shocking it was my friend .
    X-cpe and SS327 like this.
