We don't know if engine is stock 305 --- seller told us it as a good engine. ( Good oil pressure / idles smooth/ does not run hot. ) However, it has a ping. Even though timing adjusted, I just added middle grade gas to the tank. ???????? What steps should be taken to eliminate the ping?
*Reduce ignition timing. *Reduce compression. *Increase octane. *Reduce engine temperature. *Reduce engine load. *Delay upshifts to avoid lugging. *De-carbonize pistons and combustion chambers. *Richen fuel mixture. *Make sure mechanical and vacuum advance are working properly and not sticking. *Check EGR valve operation if equipped. Feel free to try any or all of the above.
