SBC experts and others...whats going on??
Discussion in 'The Hokey Ass Message Board' started by Toqwik, Mar 9, 2011.
  1. Toqwik
    Toqwik
    I just put a old targetmaster motor in my project and noticed antifreeze under it. It is dripping out of one of my header collectors. Figure a crack in the head, but where? I know nothing about the motor, just bought it from a friend. Should I dump some block sealer in it?
  2. pigpen1
    pigpen1
    could be a head gasket .
  3. sdluck
    sdluck
    Pressure test cooling system
  4. BOWTIE BROWN
    BOWTIE BROWN
    No on the sealer.
  5. Rebel 1
    Rebel 1
    Stay away from the sealers. Pressure test it as stated above to see where it's coming from.
  6. This is most likely your problem...
  7. Toqwik
    Toqwik
    Forgive me for sounding dumb, but if I pressure test it and it continues to leak, then what. I am trying to get this car ready for sale.
  8. sdluck
    sdluck
    The pressure test is to find where it is leaking,if it is coming from the header, try removing the header to see if it is coming from the exhaust port
  9. Gdog3225
    Gdog3225
    from Tennessee
    The best thing to do is to pull header and see which hole is coming out of and pull that head an check for blown gasket, or cracked head. If it was mine i would have the head checked anyway whether i was sellin or not.
  10. Mr48chev
    True and a head gasket and intake gasket doesn't cost much. Heads are inexpensive and easy to find for those engines (just about any 350 head with the same size valves and spark plug holes. The plug holes are important because you don't want one style of plug on one head and the other on the other head.
  11. ciscokid
    ciscokid
    If you have water coming out of the exhaust port while pressure testing the cooling system, You either have blown head gasket, and/or bad exhaust valve guide. I had the same problem but mine was a big block. hope this helps, good luck.
  12. badshifter
    badshifter
    You sure it's coming out from inside the header? Not outside or around it? I've never seen a head gasket leak so much that it would get into the cylinder, past the exhaust valve and out the header, and not be obvious when the engine was running, or hydraulic when starting. If you pop the radiator cap when it's running does it blow out the radiator? I'd check the freeze plugs, the intake manifold at front and rear first.
  13. Retro Jim
    Retro Jim
    If it was mine I would unhook the header at the head and wipe everything good and clean . Now pressure test and see what you find out . It can be a bad head gasket or a bad head gasket caused by a cracked head . Have you checked your oil stick for the famous baby shit color oil yet or any water drops on the stick ? If you see it leaking in the gasket area it's either the head gasket or head . If you see it coming out the exhaust post then you know you have a cracked head .
    Either way I would check the head gasket over very well and look the head over very well too with a strong magnifier. Also check the head to see if it's straight with a metal straight edge and use a feeler gauge to see if you have a gap . You might need a head shaved .
    Those are the things I would do to correct the problem .
    Hope it's just a shitty head gasket !
    What ever you do NEVER EVER use a sealer on a head gasket leak !
    Retro Jim
  14. Got you, mystery one star sbc thread guy
