sbc flywheel allowable thickness
Discussion in 'The Hokey Ass Message Board' started by onegalonly, Apr 8, 2013.
  1. onegalonly
    onegalonly
    my flywheel is 1 3/16" thick... can i turn it down to .800" .... reason for question is that my RAM hydraulic bearing is is hitting the pressure plate fingers. i need a gap of 3/8" between the bellhousing to engine block in order for there to be a desired bearing set gap of .150"... RAM tech people suggested a .800 flywheel but can't find thickness specs on flywheels to order one.....
  2. 53sled
    53sled
    from KCMO
    call speedway, they list a flywheel for use with RAM clutches
  3. onegalonly
    onegalonly
    speedway tech says its (flywheel) not for stock disc..looked around and found a 1/4" spacer that i'll use..i'm sure i can cut the flywheel down 1/8".. that will give me the demension i need.. thanks
  4. onegalonly
    onegalonly
    found some good suggestions on another forum.. turned the flywheel down 3/32" and resurfaced .003.. added a 1/4" spacer between engine and bellhousing and bam! got the gap i needed
  5. saltflats
    saltflats
    from Missouri
    I though you could turn them down to were the chamfer if gonr on the edge of the flwheel
  6. onegalonly
    onegalonly
    if that is true, it is good info.. i didn't hear that on this forum or an other forum that i posted in.. all i know is that if you take too much off, the springs on the disc will hit the flywheel bolts.. learned that the hard way
  7. saltflats
    saltflats
    from Missouri
    Thats what the machinist told me because I had always wonderd had a customer that had a 1 ton 4by4 that I had put many clutches in and had the flwheel machined every time. When I asked the machinist that is what he said hell he may have been trying to pay for his flywheel reserfacer.
