SBC guys - Flexplate required for 67 283 to T350 trans
Discussion in 'The Hokey Ass Message Board' started by rat bastad, May 12, 2011.
  1. Hey guys Im in the middle of collecting parts to do this swap.
    I know the 283 SBC is internally balanced so which flexplate do I need to allow a std/very mild convertor to bolt up along with an aftermarket mini starter?
    Id prefer an quality SFI flexplate.
    Any tips would be great thanx !!
    Rat
  2. 1971BB427
    1971BB427
    from Oregon
    The std. 350 Chevy flexplate will work fine. I've got one behind my 1967 327 with a TH350.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    How many bolt holes in that mini starter. Because theres 2 sizes of flywheels 153 tooth small and 168 tooth large.
  4. The one Im scoping has 4 bolt holes....2 for 153 tooth mounting ans 2 for 168.
    So its a multifit.
    Rat
  5. Chevy54
    Chevy54
    from Orange, CA
    I just replaced mine while apart due to a crack...Mine used the 153 tooth (part# Z-114)
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I'd go with 168 tooth then. Small cubes and big wheel, it'll spin real easy that way. Hell no matter the cubes I'd always go 168 tooth.
  7. Thanx guys - what diameter should it be for a T350 ?
    Is 11" OD Ok ?
    Rat
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Either size will work. There no converter to flywheel match up on this application. I have used both sizes on T350 and so did GM.
  9. Thanx for the heads up JG !!
    Rat
  10. narlee
    narlee
    There is no 11" flexplate, the 153 tooth is just under 13 " and the 168 tooth is just over 14".
