Hot Rods SBC Harmonic Balancer and Timing Chain Cover
Discussion in 'The Hokey Ass Message Board' started by Pollywog, Jul 23, 2025.
  1. Pollywog
    Pollywog
    from Portland
    Two quick question...
    Replacing the timing chain cover on a Chevy 265 I just bought. When removing the harmonic balancer I hear a pop from the back of the motor....Was I just hearing some sorta pressure release, or am I in trouble?
    Im also having trouble getting the timing chain cover off. All the screws are out and nothing else seems to be holding it on. Im nervous to just use brute strength and ignorance to pull it off. Any clue?
    Thanks for your help and knowledge! I really appreciate the people on this board.
    tractorguy likes this.
  2. Pollywog
    Pollywog
    from Portland
    Timing chain cover is off. It just needed a little persuading
  3. check crankshaft end play (thrust). should be within .003"-.009".
    tractorguy, Pollywog and mad mikey like this.
  4. Wanderlust
    Wanderlust
    Can’t help you with the pop but loosen the oil pan bolts about half way out the pry the front of the pa down then you should be able to remove the timing chain cover.
    Ok too slow typing, well it will go better ***embling to have the pan down a bit, get the timing cover on then tighten up the pan
  5. mad mikey
    mad mikey
    You better take the oil pan off, remove timing cover, reseal all on ***embly.
  6. Pollywog
    Pollywog
    from Portland
    Watched a video on YouTube on how to do this. Thank you
  7. finn
    finn
    Drop the oil pan, force the crankshaft all the way back, then use a feeler gauge to measure clearance between the thrust bearing and the shaft. Force the crankshaft forward and measure again. The numbers should match. A better way is to buy an inexpensive dial indicator and stand and move the crank back, zero the dial, then move it forward.
    Either method works, but the dial indicator is probably more accurate. It takes some practice to get repeatable readings.
    I think HF has indicators and stands good enough for this. You’re not making a spaceship, so uber expensive tools aren’t a must. You’ll need the tools if you pursue the hobby.
    Tickety Boo, ekimneirbo and Pollywog like this.
  8. Pollywog
    Pollywog
    from Portland
    I see what you're saying about the oil pan. There a little lip holding the cover.
    Everything seems to check out, crankshaft wise. The motor is out of the car and on a stand so it was real easy to check.
    I'm hoping the pop sound was just the sound of pressure releasing.
  9. 1934coupe
    1934coupe
    What Mad Mikey said.
    Pat
  10. It it’s out, I’d do the pan as well
    deathrowdave likes this.
    Johnny Gee likes this.
  12. gimpyshotrods
    gimpyshotrods
    It's a 265 and it had a harmonic damper?
    Maybe it's the head injury talking but I thought the SBC had an undrilled crank and just a pulley pressed on, continuing until after the 283 was introduced.
  13. 1971BB427
    1971BB427
    from Oregon
    If you get it back together without replacing the oil pan gasket you're going to end up with a oil leak until you replace the pan gasket also! Don't cut corners on this part of the job or you'll regret it later.
    ekimneirbo likes this.
  14. 1971BB427
    1971BB427
    from Oregon
    You're half right. The 265 didn't have a bolt, but it did have a harmonic balancer.
    gimpyshotrods likes this.
  15. Fordors
    Fordors
    I have to agree with @gimpyshotrods , the 265 had no harmonic damper, only a hub to bolt the lower pulley to. The hub also provided a surface for the front crank seal.
  16. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Yes they have some that work fine. Also need a "magnetic base" to hold the indicator. And Yes again that its a good addition to a tool box.:)
    I'd also go on Amazon and search for a book on "Rebuilding the Smallblock Chevy". They also have used ones for about $25 but the new ones are slightly higher. This is a good place to learn a lot about your engine. Look at the various ones available and see which one suits your engine the best.
    Algoma56 likes this.
  17. RICH B
    RICH B
    Been a while; but on the 265 engines I had, the pulley was riveted onto the lower hub and had 2 threaded holes for a puller instead of 3 like the later hubs. I remember them being a harmonic damper; but like I said, it has been a while.
    The only plain hubs that I came across were on 283 truck motors and they had 3 holes and bolt on pulleys.
  18. gimpyshotrods
    gimpyshotrods
    Thank you gentlemen.
    Getting bonked on the head is a frightful experience.
